importing MKV files issues
vasilis
sound_card: nvidia GTX 2060
Hard_Drive_Capacity: 500 gb
Monitor/Display Make & Model: ASUS G731GV
Corel programs: VS 2020
Post by vasilis »
hello i noticed when importing an mkv file in timeline there not appears the icon of speaker(in red circle in attachemennt) that appears with other formats.as a result the exporting format (AVC 1920x1080) play in my tv with no sound.what is going wrong?
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Re: importing MKV files issues
Post by aljimenez »
Two possibilities: Audio format not supported, or no audio in the file. If you use a program like Mediainfo, does it show there is audio in the file? Does the clip play in windows Media Player? Where does the .mkv file come from (what created it)? You may need to convert the mkv file to mp4 using a program like Format Factory.
User for more than 10 years.
Try changing the audio level from 100%
99% is sufficient, this does work for some troublesome video types.
vasilis
Post by vasilis »
the problem is for all mkv files.with cyberlink powerdirector i have no issues.i will try lata.all mkv files playing with sound with windows media player aljimenez.how i change the audio level lata?
chris198810
Post by chris198810 »
It seems that the MKV files contains something unsupported by Corel VideoStudio.
Chris
You do not say what problems you are having?
It may be the source of the files and how they were created
Where did you get them from
MKV is just the wrapper containing the video data/ properties
Check the properties using Media Info, some of my MKV are Mpeg4 others AVC codec?
I have a few sample MKV files and they all open using VideoStudio, no problems.
Upload a sample to a sharing site, provide a share link on your post, we can try on our pc’s
vasilis
Post by vasilis »
when import mkv files in timeline there is no sound for it and for produce file.are they mkv files from torrent sites
vasilis
Post by vasilis »
perhaps lata must chnange project settings?i used the default settings : 720x576
I downloaded some MKV test files from Matroska
https://www.matroska.org/downloads/test_w1.html
The only one not to work with Video Studio was test 4, all others played video and audio.
If you download these samples maybe compare the settings, video and audio to the ones you are downloading.
A tweak on the download converter you are using may solve your audio problem
vasilis
Post by vasilis »
1)must change settings project when importing MKV files?the default settings is dvd pal 720X576
2) what do you mean about ''A tweak on the download converter you are using may solve your audio problem''?i download mkv files with m torrent
1 / I do not have a problem using the samples with any Project Property settings.
2 / Compare your video files properties with the test samples from Matroska to see if there is a difference.
Maybe a setting you can change.
Try downloading the files using different methods, a different download manager.
Does the person supplying the files have a similar problem with the originals?
Using a video converter may create a more editable format that VS can cope with.
Do you think the files may be copywrite protected? If so they may be encrypted to cause these problems.
Sorry but I am running out of ideas as to why you are having issues.
vasilis
Post by vasilis »
ok thank you
