VideoCam System AVI files don't import to Corel VS U10
Re: VideoCam System AVI files don't import to Corel VS U10
I get similar results to Kens findings, although I only see one frame, the video does not seem to play acting like an image.
I tried to convert using Format Factory which crashed with an error relating to an unsupported format.
Rev you mentioned Sorenson Squeeze version 9, did you use that program to convert your video files?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
non of my players can decode this long sample.
*****Correction, I was able to transcode it to mp4 using Xmedia recode
test_2.zip
(361.77 KiB) Downloaded 193 times
Complete name : E:\downloads\test.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 1.97 MiB
Duration : 3s 895ms
Overall bit rate mode : Variable
Overall bit rate : 4 244 Kbps
Writing application : Lavf55.48.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : H264
Duration : 3s 895ms
Bit rate mode : Variable
Bit rate : 4 220 Kbps
Maximum bit rate : 14.0 Mbps
Width : 2 560 pixels
Height : 1 440 pixels
Display aspect ratio : 16:9
Frame rate : 19.000 fps
Original frame rate : 20.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.060
Stream size : 1.96 MiB (99%)
Color range : Full
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 3s 895ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 16 bits
Stream size : 60.9 KiB (3%)
Alignment : Aligned on interleaves
Panasonic X900m, VXF1
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Have same results as Ken with VSX10, clip does play OK in Premiere Elements 15
Type: AVI Movie
File size: 1.97mb
Image Size: 2560x1440
Frame Rate: 19.00
Duration 3.26
Pixel Aspect Ratio: 1.0
MrJohnny
motherboard: ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
processor: 3.00 gigahertz Intel Core i7-5960X
ram: 32GB
Video Card: NVIDIA GeForce GTX 960
sound_card: onboard
Hard_Drive_Capacity: 8TB
Monitor/Display Make & Model: ASUS VH226
Corel programs: VS X5 Ult, VS X6 Ult, VS X9Ult,VS X10Ult
Post by MrJohnny »
The test.avi posted by Revup67 plays in both Clip and Project Modes on my system.
At first sight it looks like a still image only, but if you monitor the clock numbers top left they do change. The Timeline shows a duration of 3.26 s, MediaInfo shows a duration of 3 s 895 ms.
There must have been little/no wind because the ferns are rock steady.
John
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
I couldn't do anything with the test clip as supplied, on any of my pc's, even my editing one, which has plenty of codecs on.
I couldn't get Handbrake to load it to convert, but I could use freemake, which converted it to an MP4 file and then this could be used in any app I had, VS, Edius, Premiere etc.
