CVSX10 render crash
CVSX10 render crash
Share – Same as First Clip should be used
Render crashes program at same point for original project
I have created a short sample project, also crashing.
Timelines contain one MTS video + crossfade to Jpeg image
Titleline contains text box starting in centre of transition.
If I remove the title then render is ok but with title render crashes program
Further tests seem to indicate the Title + Jpeg is the culprit, but rendering to project settings as MTS settings.
I have uploaded a Smart Package for X10, can anyone replicate this problem.
https://1drv.ms/u/s!ApBs8FwBwJ5jiiYUuArxBJXZO56Q
Cheers
Re: CVSX10 render crash
Post by BrianCee »
No problems at all for me Trevor
downloaded your package and unzipped
opened vsp file and re-linked files
noted that the title did not start during the cross fade but two seconds into the jpeg - left it where it was - rendered 'same as first video clip'
rendered successfully
back to 'edit' moved start of title to middle of crossfade - rendered again 'same as first video clip'
Thanks Brian
The only way I could render the Jpeg and Title was to first convert Jpeg to a video file, then the combination worked.
Just rendering the full project as write this post
I must admit it is the first time I have ever had a project freeze rendering.
I had rendered the project a few weeks ago with no problems, then changed a few bits, although not these clips. Last night simply froze at 58%, repeatable.
Odd maybe my pc, could be X10 and SP1?
Oh rendering to MP4 was not a problem???
A few more tests shows the problem with CVSX9, but ok when using CVSX8
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
No problems in my laptop running X10, no problems running X9; my laptop runs Windows 10. My big pc (details on the right) running Windows 7 Professional running X9 also has no problems.
User for more than 10 years.
Thanks Al
It does appear to be my pc environment, but then strange that X8 works ok.
can I ask, what version of CVSX10 are you running.
I am using X10.1.0.14 64 bit.
aljimenez
ram: 24GB
Post by aljimenez »
I had X10 10.0.0.135 when I posted earlier. When I went in X10 to get the version I had, the dialog popped up about SP1 being available. I accepted and it installed. My X10 in the laptop is now 10.1.0.14 (64 bit). I reloaded your crash VSP and rendered as project settings and it worked fine.
Thanks Al
maybe I should try a re-install?
MrJohnny
motherboard: ASUSTeK COMPUTER INC. RAMPAGE V EXTREME
processor: 3.00 gigahertz Intel Core i7-5960X
ram: 32GB
Video Card: NVIDIA GeForce GTX 960
sound_card: onboard
Hard_Drive_Capacity: 8TB
Monitor/Display Make & Model: ASUS VH226
Corel programs: VS X5 Ult, VS X6 Ult, VS X9Ult,VS X10Ult
Post by MrJohnny »
Trevor
Same as all the other respondents - renders OK. Tried both User Accounts, same both times - all OK.
Running X10.1.0.14 both set-ups. Is X8 64 bit or 32 bit? I missed that version and X7 too.
John
