Thanks for your help, but I think that I've been misunderstood ...
Lata, if you look on the left end of the green bar, the size is reported as 4.71 GB. When the DVD is burned, the size is considerably smaller.
What I'm trying to discern is WHY the program reports the estimated usage as so much LARGER than it actually is. In this particular case, the DVD is actually LESS THAN 3 GB when burned ... there is absolutely NO OVERBURN (not sure of the correct expression) involved. You can visibly see on the disc that the area burned to is less than 75 % of the disc. File manager backs up that visual cue showing the volume to be only 2.8 GB.
For this project the settings are:
Code: Select all
MPEG files
24 bits, 720 x 480, 29.97 fps
Upper Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
Display aspect ratio is 4:3
Field type is Upper field first
I have the following items checked:
Code: Select all
Do not convert compliant MPEG files
Treat MPEG audio as non-DVD compliant
Autorepeat when disc playback ends
On OTHER PROJECTS, the program has reported size as being 5 - 6 GB (Not the project shown here) and yet burned on a single DVD with no overburn. Again, unused space is visible on the disc.
It would just be advantageous to this old guy if the program ACCURATELY (within 10% even) reported the estimated size of the project when burned to disc. As it is now, some of my projects are as much as 40% smaller than the program shows them to be.
@skier-hughes, I've burned with VS. I've created ISO and burned with Nero (sometimes I make several copies of the same compilation). Size of the burned disc is almost identical either way.
