X10.1.0.14 Share panel wrong display
Chaofei
motherboard: ASRock H61M U3S3
processor: Intel I5-3570
Video Card: Nvidia GTS -1050
sound_card: Realtek onboard sound
Monitor/Display Make & Model: Samsung 22 Inch
Corel programs: Corel Videostudio X9 Ultimate
Re: X10.1.0.14 Share panel wrong display
Post by Chaofei »
lata wrote:Hi chaofei
When you say “encounter same problem here”
Are you referring to the share panel, if yes --- you may be best manually rearranging the panels to display the Start buttons etc.
Or are you referring to Tony’s Serial number issue?
Unless someone has informed Corel Support I doubt they are aware.
I reinstalled my program and things worked ok, so I do not know why the problem showed in the first place.
Ops sorry, yes serial number issue, actually i am very happy CSV MCE issues already got fix, but alas now the update patch wont install, the Mercalli “X” line make me keep using X9.....
Please download the patch from here and try again to install the patch.
http://www.videostudiopro.com/en/suppor ... sion-tab=0
Double click VSX10_SP1.exe to install.
Usually installing patches do not install again, but this SP1 appears to break the rules.
If the above does not work then I think you should re-install the main program.
I also thought there was a Graffiti program for X10, although I do not see that in Programs and Features,(must be dreaming??) if you have such an entry for X10, uninstall before installing the main program.
Chaofei
Post by Chaofei »
lata wrote:Hi
Thanks for your quick reply bro Trevor, great apreaciate it.
Actually the SP1 i downloaded is from that link too.
Both version CSV I installed as i mention above got same problem....
