Color Changer tool
FlaHillbilly
motherboard: ASUSTeK COMPUTER INC. CM6330_CM6630_CM6730_CM6830_
processor: 3.40 gigahertz Intel Core i7-3770
ram: 16 GB
Video Card: NVIDIA GeForce GT 630 [Display adapter]
Corel programs: PaintShop Pro X9,
Color Changer tool
Post by FlaHillbilly »
I am having a problem selecting the Color Changer Tool. In toolbox it coexists with the Flood Fill and Gradiant Fill tools. You seem to be able to select one of the three. However, whenever I select the Color Chanter (or gradiant fill, for that matter), I have a problem. The icon on the toolbox palette shows the correct icon (Color Changer or Gradiant Fill), but when I move the cursor over to the image, it only appears as the Flood Fill icon and it only behaves as the Flood Fill Tool. How do I actually get the Color Changer tool up to use on an image?
Thanks for any help or suggestions.
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Color Changer tool
Post by Kathy_9 »
You could try resetting the tool by selecting the tool and clicking on the Preset icon on the Tools Toolbar and then clicking on the arrow. If you hover over the arrow you will see it says Reset to Default. If that does not work your can try the following method.
https://support.corel.com/hc/en-us/arti ... figuration
Note: The above knowledge base article references PSPX6 but it will work for any version.
FlaHillbilly
ram: 16 GB
Thanks for the suggestions. I tried them, but to no effect. No matter which of the fill tools I select from the toolbox, only the Flood Fill tool seems to track the cursor over the image and to be available.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
There does not seem to be a different icon for the Color Changer tool. It has the same icon as the flood fill (at least as far back as PSP X2 that I could test). Its activity also looks like a flood fill but in various shades whereas the flood fill has the same shade and density in all places it is applied.
You can see the usage of the Color Changer in this video from Corel using X5
http://learn.corel.com/tutorials/color-changer/
FlaHillbilly
ram: 16 GB
Thanks, I think that was the problem: I had the mind set that the icon at the cursor should match the icon on the toolbox panel.
