Can you scroll over a masked proxy?
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Due to a problem I had last week I have to use proxy files now.
When I placed one as overlay and mask it it looks fine as long as it stopped, but when scrolled over or played the mask goes berserk . It renders well (for the one test I did) using original clip do not have that illness.
Panasonic X900m, VXF1
Re: Can you scroll over a masked proxy?
Hi Asik
I do not really understand, I assume you have applied Chroma Mask Frame.
Is it just the kaleidoscope effect of the moving squares that’s confusing, if you view the video after 4 seconds does the mask look static?
asik1
- ram: 8gb
Trevor, select any mask over a proxied file , scroll or play it . Do you see the mask correctly?
it's that simple.
it's that simple.
Hi asik
Adding a mask frame looks ok and static when playing or scrolling over the clip, I do not see any problems
Then I am having problems with the Chroma key on the other post,????
asik1
- ram: 8gb
here the culpritlata wrote:Hi asik
http://www.filedropper.com/capture01
Do you think it's this old system thing? it's a core duo E7400 with 4GB ram, GT9500 and all SSD.
Sorry asik but I cannot find the capture01 file on that site, all I get is the site trying to install other bits and pieces.
Do you have another link to a direct download rather than File Dropper
Usually a right click and Save Target As works but not for that link.
Have you tried Microsoft One Drive, Google Drive or DropBox all seem pretty simple to use.
asik1
- ram: 8gb
I don't have those, but why here I don't need to install? all I need is pressing "download the file" and type the code and get the filelata wrote:Hi
(it's a german site)
It's just 2mb file.
Well I finally found that link after wading through the rest of the junk.
Maybe we see a different window to you, we are not registered so the web site tries to get us to install / register for File Dropper
No I do not have any problems like that, my mask works ok.
Can you zip your VSP and attach to the post, cheers
asik1
- ram: 8gb
Trevor, have you make sure the file is proxied? only than there is problem.
Yes the file has poxies
asik1
- ram: 8gb
OK, I'll dig deeper.
**** Well, if I set the proxy at the default Auto (recommended) .upx file, than the culprit gone, but the proxy file is larger or about the size of the original HD file (MB wise) .
The culprit shows only on all the other different templates, so can you confirm that trevor?
I have set proxies to use these settings, same as video being used.
No problems
MPEG-4 Files
24 bits, 1920 x 1080, 25 fps
Frame-based
H.264 High Profile Video: 15000 Kbps, 16:9
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 256 Kbps
No problems
MPEG-4 Files
Frame-based
