Working with iPhone Slow Motion Files
qtrim
motherboard: ASUS P5QL PRO 775 P43
processor: Intel Core 2 Quad Processor Q9550 2.83GHz 1333MHz
ram: 4GB
Video Card: NVIDIA GeForce 9400 GT
sound_card: Onboard Asus Audio
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung T260HD 25.5-Inch LCD
Post by qtrim »
So I have video shot on an iPhone, 720p, H.264, at 120 fps. I plan the final render to be 720p at 30fps.
There's a section that I want to show in slow motion, taking advantage of the 120fps. If I go to Video/Speed and Time Lapse, should I just set the speed to 25% (since 30fps is 25% of 120fps), or would I also need to specify something in the frame frequency field?
Using VideoStudio since old Version 7. Currently using X10.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Working with iPhone Slow Motion Files
Post by asik1 »
qtrim wrote:So I have video shot on an iPhone, 720p, H.264, at 120 fps. I plan the final render to be 720p at 30fps.
As far as we know VS do not have native support of HFR files and the frame frequency field is useless since X8X9X10
it's a bug not fixed yet.
Panasonic X900m, VXF1
Video Studio timelines set a frame rate according to our video frame rate, this is normally 30 or 60 fps for NTSC video.
There is no option to set the timelines to use 120 fps.
Consequently adding your video to the timeline having 60fps will only display your video at 60fps, effectively removing every alternative frame.
The video may look and play ok within the program.
How long is your video?
You could rip the video frames to images, (Video to Jpeg Converter) there would be a lot, then you can add all images to the timeline set to 1 frame duration .
The timeline being set to 29.97 / 30 fps would play your video in slow-mo.
