'Mask Show All' icon
Phil47
motherboard: ASUS Z170-P DDR 4
processor: i-5 6600K OC
Video Card: GTX960
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: Asus MX279
Corel programs: PSP X6 PSP X9 PSP 2018
Post by Phil47 »
Where is the 'Mask Show All' icon please?
It mentions it in this tutorial - http://www.pixalo.com/articles/Photo-bl ... op-pro.php
It says, "Then click on the 'Mask Show All' icon at the top of the palette." I looked everywhere but can't find it. Maybe the article is 20 years old or something.
I want to blend two photos but can't find anything relevant to PSPX9.
Tell the truth....but gently.
Phil.
Kathy_9
Hard_Drive_Capacity: 2TB
Re: 'Mask Show All' icon
Post by Kathy_9 »
The icon looks like the mask the Lone Ranger wore. In order to see it make sure your Layers Palette is visible. To enable the Layers Palette go to View -> Palettes -> Layers. Click on the Mask Icon and it will open the box shown above by the arrow.
Click for larger view
csh2000
processor: Intel Core i7-6500U CPU 2.50GHz
ram: 12GB
Hard_Drive_Capacity: 1TB
Corel programs: PSP X9, Aftershot Pro 3, VideoStudio X9
Post by csh2000 »
The instructions on the website you are referencing will not work. Instead of "show all", you should be selecting "Mask from Image" on the top layer. If the top layer contains blown out sky as in the example, then you will need to also select "Invert Mask Data".
csh2000
ram: 12GB
Post by csh2000 »
csh2000 wrote:The instructions on the website you are referencing will not work. Instead of "show all", you should be selecting "Mask from Image" on the top layer. If the top layer contains blown out sky as in the example, then you will need to also select "Invert Mask Data".
DOH!!! I stand corrected... After, I reread the instructions.. This does work as advertised..
Phil47
Video Card: GTX960
Post by Phil47 »
Thanks Kathy - found it and will try again in the morning.
Phil.
Kathy_9
Post by Kathy_9 »
You're welcome.
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Post by flagpole »
How exactly does this work? I've never pasted anything into a mask layer before.
Oh no i get it. It uses a black and white copy of the the background as the mask so as it happens only the sky is visible being as it is lighter.
Clever.
