Creative Content Pack Issues
stretch65
motherboard: Asus P9X79 Pro
processor: Intel Core i7-3930K [6 cores]
ram: 32 GB
Video Card: NVidia GeForce GTX 1080
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 2.25 TB
Monitor/Display Make & Model: Acer 23 inch
Corel programs: Paint Shop ProX9
Post by stretch65 »
I've just purchased and installed Paint Shop Pro X9. I've also installed some content packs including a Creative Content pack (about 200 MB). When I installed the software I chose the recommended option which was to install both 32 and 64 bit versions. I chose drive F as the location for the software (instead of my OS drive (C) which has limited space).
Now, when I start up Paint Shop Pro, I can't seem to find the stuff that's in the Creative Content pack. The installation has created a user content directory at "C:\Users\Owner\Documents\Corel PaintShop Pro\19.0". Most of the subdirectories in this directory are empty. The Creative Content stuff doesn't seem to appear anywhere in PSP's Navigation Pane. I've looked around and found that the content was automatically installed at "C:\ProgramData\Corel\Corel PaintShop Pro X9" but this location isn't even listed in the Navigation Pane. Is there something I need to do so I can view and access this content?
Also, the user content directory for me isn't really in the ideal location. I'd prefer it to be on another drive, instead of my OS drive. Is there anyway I can move it? And can I move the Creative Content stuff to another drive as well?
Thanks.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Creative Content Pack Issues
Post by LeviFiction »
These resources are available in the individual tools where the resources are used. Brushes will show up in the paint brush options, frames in the add a frame command, gradients int eh materials palette, textures and patterns in the materials palette. The backgrounds are saved in the Public Pictures folder.
Rick_R
motherboard: ASUSTeK Computer INC F2A85-V Pro
processor: AMD A6-6400K APU
Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
sound_card: On-board Realtek and AMD High Definition Audio
Hard_Drive_Capacity: 16TB+375GB
Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
Corel programs: PaintShop Pro 12-2022 Ultimate
Post by Rick_R »
There are two ways to deal with all the add-ins (brushes, frames, etc.) Those are saved at C:\ProgramData\Corel\Corel PaintShop Pro X9
I'll refer to that as the "source" folder.
One is to simply move those and then add the target locations: Menu > File > Preferences > File Locations.
The other is to move the source folder itself and use a junction to point to the new location.
For instance, with PSP closed:
1) Create F:\Corel_PSP\Corel_XX
2) Copy everything in the source folder to there.
3) Rename all the source folders by adding a minus sign at the beginning.
So, you copied \Corel_01 to F:
You rename C: ... \Corel_01 to \-Corel_01
4) In the source folder, create a junction named Corel_01 that points to F:\Corel_PSP\Corel_XX\Corel_01
5) In the Windows Explorer Navigation Panel click on the Corel_01 junction. You should see a list of files.
6) Compare the list showing in the junction with the original at \-Corel_01. They should be the same.
If they're not, you screwed up the junction. "Uncreate" the junction and try again. Don't try to delete the junction like deleting a folder--that will actually delete the real files in the target folder.
7) Once you have the source and target folders matching, delete the files in the "minus" source folder and its subfolders. Don't delete the folders -- they don't take up much room and it helps having them if you ever have to undo everything.
8) Repeat for each of the other folders you want to "move".
A junction is similar to a shortcut. The difference is that junctions are transparent to programs. Once you have the F: ... junction properly set up, PSP will see the the files as still being in C:\ ... Corel_01 exactly as if you hadn't done anything. But the files will actually be on F:.
I'll put code in a separate response.
Rick_R
Post by Rick_R »
Code: Select all
@echo off
:: CREATE A SET OF JUNCTIONS FOR CERTAIN PAINTSHOP PRO FOLDERS
:: Requires TCC/LE or TCC from www.JPSoft.com
:: Creates a set of junctions from C:\ProgramData\Corel\Corel PaintShop Pro X9 to a target folder
:: Below, change S:\Program_Data\Corel\PaintShop Pro\Corel_XX to YOUR target folder.
:: Then save with a .btm extension in C:\ProgramData\Corel\Corel PaintShop Pro X9
:: Folders there with the names Corel_01, Corel_02, etc., must be copied to the target folder.
:: Then the source folders must be renamed before running this.
:: Then run this.
mklink /J "Corel_01" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_01"
mklink /J "Corel_02" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_02"
mklink /J "Corel_03" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_03"
mklink /J "Corel_04" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_04"
mklink /J "Corel_05" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_05"
mklink /J "Corel_06" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_06"
mklink /J "Corel_07" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_07"
mklink /J "Corel_08" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_08"
mklink /J "Corel_09" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_09"
mklink /J "Corel_10" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_10"
mklink /J "Corel_11" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_11"
mklink /J "Corel_12" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_12"
mklink /J "Corel_13" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_13"
mklink /J "Corel_14" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_14"
mklink /J "Corel_15" "S:\Program_Data\Corel\PaintShop Pro\Corel_XX\Corel_15"
Rick_R
Post by Rick_R »
DOCUMENTING JUNCTIONS It's a good idea to document junctions, since they're not obvious.
In the SOURCE folder that contains the junctions (in the example, C:\ProgramData\Corel\Corel PaintShop Pro X9 ) AND in the TARGET folder I put a file named JUNCTIONS LIST.TXT that contains the information below in blue. You would need to change S:\Program_Data\Corel\PaintShop Pro\Corel_XX to your target folder.
Note that the actual code to create the junction is listed. If you're going to set up junctions manually, copy and paste that code to TCC/LE and run it. If it works (which it should), fine. If it doesn't work, change the code in the file and copy and paste again. That way you will have documented whatever did work--you won't have code in the file that doesn't actually work.
On Rick Win 10 Pro x64:
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_01
was replaced with a junction to:
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_02
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_03
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_04
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_05
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_06
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_07
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_08
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_09
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_10
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_11
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_12
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_13
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_14
C:\ProgramData\Corel\Corel PaintShop Pro X9\Corel_15
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Rick_R wrote:There are two ways to deal with all the add-ins (brushes, frames, etc.) Those are saved at C:\ProgramData\Corel\Corel PaintShop Pro X9
[REMAINDER SNIPPED]
Given that moving (or copying) the folders and then pointing PSP to the new location is an operation using a couple of steps, and your descriptions of how to create junctions (plus the code plus the fact that you have to have a way to remember junctions because they aren't transparent) is somewhat involved, why would one want to create junctions? Just curious...
JoeB
Using PSP 2019 64bit
