Why can't I fill a selection?
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
Post by terrypin »
I made a careful selection and am trying in vain to fill it with a single colour, but PSP 8 (not X8) remains unresponsive when I click with the Fill tool. Tried various 'modes'.
The setttings seem OK to me.
I was able to do it with the Brush, but why not the Fill Tool?
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Re: Why can't I fill a selection?
Post by flagpole »
So the fill tool doesn't work like that. It's designed to fill all the areas of one specific colour and change them to another.
Think if you were to just click in an image you would expect this behaviour. You would expect it pick out and select all the areas of one colour.
The way to do it is to add a new layer and fill that.
(or possibly to increase your tolerance to 255 but it's certainly not the best way.)
Selections limit the area in which a tool can act, but it is not required that they act in that area.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Or change the match mode to All Opaque and it will fill with that color. If you change the Blend mode before filling it will fill with the blended effect of that color and depending on what blend mode was selected.
LindaSue
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
Even if you set the Match mode to None or All Opaque, you've got the opacity set to "1" so you would only fill the selection with a very faint or nearly invisible color. Is that your intention?
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
hartpaul
ram: 8 Gb
Post by hartpaul »
Good catch LindaSue, missed that. :D
flagpole
Post by flagpole »
Yeah good spot.
hartpaul
ram: 8 Gb
Post by hartpaul »
Another good reason to reset your tool to default - presets down arrow and Reset to Default button on right. If something nort working properly - reset to default.
flagpole
Post by flagpole »
Opacity is of course often given as a decimal fraction. Just not in this case where it's converted to a percentage.
terrypin
ram: 32 GB
Post by terrypin »
Thanks all, much appreciate that helpful feedback.
I'd clearly misunderstood the function of 'Fill', which I now gather seems much more like a 'Replace colour' feature.
And I'd completely missed that Opacity setting, so in future I'll reset to defaults more carefully.
Presumably the consensus on how to accomplish my aim (fill that selection with a solid colour) is, as I found, to use the Brush, set to a large size?
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
Flood fill, tolerance 200 (maximum in X7), opacity 100 should do the job.
Tolerance 200 takes care of every pixel, opacity 100 makes it opaque, not (semi)transparent.
terrypin
ram: 32 GB
Post by terrypin »
Thanks, that works fine here in PSP 8.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Match mode of "None" just fills without caring about the color of the pixels. Tolerance won't figure into it at all. As LindaSue mentioned earlier.
terrypin
ram: 32 GB
Post by terrypin »
Thanks, that's even easier and what I must have been doing in the past - though presumably with opacity at its correct default of 100.
