PSP X9 and pre;loaded scripts
I hope I have posted this in the correct place. I am new to PSP and have the trial version of X9. X9 came with a bunch of pre loaded scripts. Is there somewhere I can go to get a description of what the pre loaded scripts for X9 will do? I tried downloading the "free scripting guide" mentioned in the X9 user guide PDF, but when I installed it, it told me this was a pdf file that contained scripts for X7, which appear to be completely different that the preloaded scripts for X9. Thanks
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: PSP X9 and pre;loaded scripts
The Scripting guide is for people who want to get started scripting. I don't think there is a comprehensive list or description of the scripts.
For the most part many of the scripts names are self-explanatory. And for those that aren't, you can hit the "Edit Script" button. This will either open the script in a dialog where you can see a "Description" of the script. Or it will open in notepad where one of the top lines in the file is labeled "Description" and that will tell you what the script is for.
Here is the full list that I have.
1) One Step Photo Fix and Noise Removal - Performs the functions "One Step Photo Fix" followed by "One Step Noise Removal"
2) Resize to 4x6 Landscape - resizes the image so that the width is 6" and the Height is 4" followed by photo fix and noise removal
3) Resize to 4x 6 Portrait (with sharpen) - Same as above but height is 6" and width is 4" followed by photo fix and nosie removal
4) Resize for Blogs - resizes the image to 600pixels wide height is calculated automatically
5) One Step Noise Removal - Runs One Step Noise Removal
6) One Step Noise Removal for noise images only - performs One Step Noise Removal twice
7) Brighten - Performs One step Photo Fix
8) Increase Color Saturation - Duplicates the selected layer, sets new layer to Soft Light blend mode with opacity of 52%, then flattens the entire image down to a single layer
9) Brighten and White Balance - Performs Fade Correction command
10) Sharpen - Performs Sharpen command twice
11) Greyscale - Converts image to greyscale
12) Vintage - Performs Time Machine photo effect with Albumen setting
13) Comic Line Art - performs several tasks to make the image look like a comic book page. At least it tries, it's not very convincing.
14) Black & White - Performs Fade Correction - auto adjusting color levels - and threshold to create a black and white image
15) Add White Border - performs Add Borders command with a white border
16 - 20 ) Resizes for blogs and then adds either a big or small border in either white or black.
Airbrush and Ink - attempts and artsy look with a heavily involved script
Art - uses Brush Strokes command and layer properties to created a painted feel
Bevel Selection - uses Bevel and Drop Shadow on a selection
Black And White - Creates a Black and White Pencil Effect
Black and White Pencil - A different method of the pencil effect
Black and White Sketch - aims at a sketch effect
Border with drop shadow - simulate an object floating above the image
Capture Palette - creates a psudeo-palette - an image with a bunch of squares representing the basic colors inside the image
Center Layer - centers the active layer on the canvas
Charcoal Effect - creates a charcoal drawing effect
Color Sketch - colored pencil effect
Colored Chalk - colored chalk effect
Dot Method - pen and ink effect
EXIF Captioning - places Camrea and Exposure information at bottom of image, if those values exist in the EXIF tag information
Find All Edges (color) - Split to RGB and then find all edges, creates a colored outline image.
Find All Edges (Legacy) - An older method to find all edges that used the User Defined Effect dialog
Find horizontal edges (legacy) - Duplicates the Edge Effects>Find Horizontal command in Paint Shop Pro 8 and earlier versions of Paint Shop Pro.
Find vertical edges (legacy) - Duplicates the Edge Effects>Find Vertical command in Paint Shop Pro 8 and earlier versions of Paint Shop Pro.
Find reticulate - Color reticulation effect - Reticulation is the formation of a network of wrinkles or cracks in the photographic emulsion.
Flag - Makes an image into a waving flag
Full image drop shadow - creates a duplicate image with a white border and a drop shadow making the image appear to float above the surface
Grey Chart - Creates a new image with all of the grey values as bands on the image
Greyscale border - Puts a grayscale border around an image
GreyscaleInPlace - Convert the current layer or selection to greyscale. Only supports BGR and BGRA data.
Guides - Golden Ratio - creates guides on the image indicating the golden ratio
Guides - Rule of Thirds - creates guides on the image indicating the rule of thirds
Infrared Camera - Makes an image look like it was done with an infrared camera
Japan Style Brisk - Japanese Art effect
Japan Style Light - Another effect with slight differences
Japan Style Nature - Another effect with slight differences
Large Mosaic Effect - creates a large mosaic effect
Lexar Active Memory Batch Script - meant to be used in batches, it sets "Active Page' EXIF value and then performs one step photo fix. Unsure what the use is.
Mosaic - Regular sized mosaic effect
Night Vision - Makes an image look like it was taken with a night vision camera
OneStepPhotoFix - runs onestepphotofix command
OpenDuplicate - Runs Open command then creates a duplicate of the images selected and closes the original
Painted carved wood - image looks like it was painted on a carving
PaletteFromImage - Create a palette from the open image. The user is prompted for the number of colors to use.
Photo Edges - Adds space around an image and creates and edge effect. Additional effects can be achieved by altering the Brush Strokes dialog.
Pointillist - A color pointillist effect
Sepia Frame - Create a sepia frame effect from an image landscape mode
Simple Caption - Place a caption on an image by expanding the canvas and placing the caption below the image.
Sloppy Edges - Adds a deckled sloppy edge to an image
SmartPhotoFix - runs SmartPhotoFix command with preset greyscale values for white-balancing
SplitCMYKtoLayerGroup
SplitHSLtoLayerGroup
SplitRGBtoLayerGropu - these three scripts run the "Split Image -> CMYK, HSL, and RGB commands respectfully. It then copies the result of the split into a layer group on the source image
ToggleCursors - Toggle between precise cursors and show brush outlines.
ToggletoSelection - Emulate the Corel behavior of toggling from the current tool to the selection tool.
Toned Greyscale - Greyscale with color tone effect.
VectorMergeAndCutoutSelected - Merge the selected objects into the first object selected rewind the contours to create a cutout effect
VectorMergeSelected - Merge the selected objects inot the first object selected
Vignette - A simple vignette effect.
Watercolor - A simple watercolor effect.
Wet watercolor - Another watercolor effect.
Thanks Levi for this list, it has helped a lot. I especially like the simple caption script, although I didn't care for the drop shadow effect it did, so I modified the script and commented out this part of the code. I see also that the grey background tends to make some pictures a little dark and adjust photo fix doesn't really fix them after this script is applied, so I am looking into changing the background canvas colour. Thanks again for the list.
