How do I make 1 color gradually transition into another?
Geoffrey
Corel programs: Corel PaintShop Pro X8 (64-bit)
Post by Geoffrey »
I am working with Corel PaintShop Pro X8.
I am having trouble finding the right words for what I am trying to do, but a picture is worth a thousand words:
Notice the background colors gradually go from green at the top to yellow at the bottom. It's not simply two blocks of color with the border faded. It's like a little slice of the color spectrum, gradually changing from green to yellow.
How can I do that? Any guidance would be much appreciated. :)
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: How do I make 1 color gradually transition into another?
Post by LeviFiction »
With gradients.
In the materials palette if you click on the foreground color you'll get the color picker dialog. In the color picker dialog there is a "Gradient" tab. This lets you choose pre-made gradients or design your own. Gradients gradually move from one color into another. You get to choose which colors, how far apart they are, and where the middle of the change is.
Here is the documentation on using Gradients
http://help.corel.com/paintshop-pro/v19 ... ients.html
Gradients can then be applied with the paint brush tool, the fill tool, or as a fill inside of a vector object.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
What you are after is a gradient.
In X8 and others this is obtained by double clicking the Foreground and Stroke or Background and Fill Properties boxes.
You then get the Material properties dialog with 4 tabs across the top:
Color , Gradient , Pattern, Texture.
Click on the Gradient tab and you should see 6 of the available gradients.
They start with Black-white, Blue metallic and if you scroll down you should find one (they are in alphabetical order) that says Foregrou... - hovering over it it will say Corel_06_029 and is actually a Foreground -Background gradient.
If you have previously selected a green and a yellow for your two colors then selected the Foreground - Background gradient and click OK then you can flood fill a blank white canvas with just the effect you are after.
I tried searching for a simple gradient tutorial on Youtube but many are for earlier versions or the latest gradient effect in X9. Many have very poor sound and are most unsuitable.
However if you open X8 and click on Help > Help Topics and type in Gradient and search you will find a section "Using Gradients" where the use of gradients is explained in reference to X8.
Geoffrey
Post by Geoffrey »
Update:
Finally did it.
Thank you for your help!
TimW
motherboard: ASUS M5A99FX
processor: AMD FX8350 8 core 4.0GHZ
Video Card: AMD Radeon HD 6900 Series
sound_card: On Board
Hard_Drive_Capacity: 256GB SSD
Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
Corel programs: PSP X8, Knockout 2
Post by TimW »
Very good info by hartpaul & LeviFiction. There is another way to achieve this in PSP X8. Go to <Effects>, <Photo Effects>, <Graduated Filter> there you can see a Before & After view. Pick your colors to blend then play with the sliders a bit 'till you get what you want. A vertical bar with end handles (in the right pane) let you adjust the transition in a multitude of ways.
latitude
Corel programs: PSP X2 X3 X6 X8 X9
Post by latitude »
hartpaul wrote:What you are after is a gradient.
I just tried doing it this way and it works fantastic, thank you for the instructions :)
