Script - Convert 256 Color to TrueColor with Transparency
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Script Name: ConvertToTrueColorWithTransparency
Download Link: https://drive.google.com/open?id=0B8FlF ... XJHRVYzM0U
Compatability: 9 to X9 supposedly
Requirements: Place in Scripts-Restricted Folder
Description:
This is of a very limited use. Occasionally you will download a PNG or GIF from the internet that uses palette transparency. Unfortunately, PSP does not support converting palette Transparency into actual layer transparency.
This script will increase the image depth to 32-bit and convert the paletted transparency into full layer transparency.
It does this by first verifying that your image is a paletted image and that it supports transparency. Then it sets the transparent index color to a unique value, finally it selects all pixels that match this new value and deletes them. The end result is a fully transparent image you can use as you see fit.
