Cant Install PSP X8 32 bit version
storm36
processor: intel CORE i5-2500 CPU 3.30GHZ
ram: 8 GB
Hard_Drive_Capacity: 4 TB
Corel programs: PSP X, PSP X4, PSP X7, PSP X8
Post by storm36 »
i was given PSP X8 as a gift last year .. running Win 10 Pro 64 bit .. not sure where my daughter purchased it from but the package came with 2 disks 1 with 64 bit version, the other 32 bit version however the Corel help files states when installing the 64 bit version there is an option to install the 32 bit version, this option did not appear .. not realizing my system supports 32 bit i went ahead and just installed the 64 bit .. but now i am finding i desperately need my plugins from my earlier PSP versions which are all 32 bit .. so i uninstalled the 64 bit and tried installing just the 32 bit version .. it wont install .. when the installer first starts, it does not display an install location so i have to point it to the program files (x84) folder when it gets to 33% complete it stops and displays an error message which just means the .Net framework need to be repaired which i did by downloading and running the tool .. but that still doesn't let me install the 32 bit version .. any suggestions on how i can get both versions installed on my system?
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Re: Cant Install PSP X8 32 bit version
Post by Zantara »
Hiya,
Did you use the cleanup tool to remove X8? If you use the uninstall option of both Corel or Windows, files are left that causes problems when trying to (re-)install your PSP version.
Furthermore, older plugins won't work with both versions installed.
You need to remove your 64-bit version with the cleanup tool for X8: http://forum.corel.com/EN/viewtopic.php?f=56&t=52337
Then install the stand-alone 32-bit version of X8.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
You can have both 32 bit and 64 bit versions of PSP X8 installed .
You can only run either the 32 bit version or the 64 bit version of X8 at any one time on that computer.
The older 32 bit plug ins will run only with the 32 bit version of X8 running.
Some newer plugins are now compatible and will only run with the 64 bit version of X8 eg Particleshop
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Post by flagpole »
Run the clean up tool. then download it from here.
http://www.paintshoppro.com/en/pages/download/
would be my advice....
Rick_R
motherboard: ASUSTeK Computer INC F2A85-V Pro
processor: AMD A6-6400K APU
Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
sound_card: On-board Realtek and AMD High Definition Audio
Hard_Drive_Capacity: 16TB+375GB
Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
Corel programs: PaintShop Pro 12-2022 Ultimate
Post by Rick_R »
A slight clarification about hartpaul's statement.
It is correct that you can only run either the 32-bit or the 64-bit version of a single "X" version at a given time, i.e., you can't run both 32-bit X8 and 64-bit X8 simultaneously.
However, you can run both for different versions, and for a number of recent past editions there have not been substantial differences. I have 32-bit X8, 32-bit X9 and 64-bit X9 installed and I can run 32-bit X8 and 64-bit X9 simultaneously.
