Bit Rate for DVD Creation
garywood84
I have recorded some video onto my computer using a TV Card (Hauppauge WinTV PVR-250). It's in MPEG 2 format, with a bit rate of 6400 kbps (CBR).
I am trying to use VideoStudio 8 to create a DVD containing four such videos, each of which is one hour long. On the Create Disc wizard I have set a custom setting with a bit rate of 2250 kbps (CBR) and MPEG sound 192 kbps.
However, the completed project is unacceptable because it suffers from severe pixelation, expecially on fast moving pan/action sequences.
I can't understand why this is, because I have tested this bit rate is of sufficient quality by capturing some video from my TV card using the same bit rate values and this is not distorted in any way.
Can anyone advise me why the conversion is creating pixelation and if there is anything I can do to avoid it?
Gary
Gary
garywood84
Thanks for your reply kebrinton.
I'm not sure what the quality of VHS relates to in terms of bit rates - perhaps you can advise me further?
I figured that 4 hours on a DVD wasn't unreasonable. DVDs of TV series that you can buy usually contain about 8 episodes (i.e. up to 8 hours) although they are on the equivalent of a dual layer DVD (DVD9) disk. This is why I reasoned that with half the capacity I ought to be able to achieve decent quality with 4 hours of film. Somebody please correct me if I'm wrong.
As a matter of interest though, does anyone know why the pixelation occurs? When I used to make SVCDs I never had pixelation problems, even with bitrates lower than the ones I'm talking about here.
Gary
Gary
THoff
hocksteo
rwindeyer
The short answer: I don't know.
Personally, I burn my home movies - from digital camcorder - at maximum quality. (VBR, 8000). That's about 70 mins per disc, with AC-3 audio. I have also been transcribing some VHS tapes; the incoming signal is not as clear as digital video; I have found that VBR around 4000, with AC-3 audio, has allowed me to get nearly 2 1/2 hours on a disc, with identical quality to the original tape.
Bitrates
(720 X 480 @ 9mbps): 64 minutes Est = 4,661.1mb
(720 X 480 @ 8mbps): 72 minutes Est = 4,675.4mb
(720 X 480 @ 7mbps): 82 minutes Est = 4,677.4mb
(352 X 240 @ 4mbps): 140 minutes Est = 4,669.1mb
These are general estimates, but can vary depending on the codec being used and the audio codec being used.
Phenom X4 965 3.4Ghz, 8gig DDR3, 120GB SSD, 1TB HD, 500GB, Bluray & DVD Burners, ATI HD5550, Epson scanner, Canon 9000Pro, Sharp AL1551CS laser printer, Sony TRV740 8mm digital, Canon HV20 and Sony SLTA65VK, Win7 HP 64bit
Gary Russell
TNUSA
Gary Russell
TNUSA
Bit Rates using a DVD recorder
I have found the following bit rates are applied to dvd recorded on a stand alone recorder
For 2 hours 4650 with screen size of 760 by 576
For 4 hours 222o with screen size of 352 by 576
Howell
Howell
THoff
Those resolutions are slightly off. For Full D1 resolution they should be either 704x576 / 720x576 for PAL or 704x480 / 720x480 for NTSC, and for Quarter D1 / CIF they should be 352x288 for PAL or 352x240 for NTSC. CIF is close enough to VHS tape in recording quality that most people can't immediately tell the difference.
Do you know if the recordings are made with CBR or VBR bitrates?
Half D1 looks fine...
The FullD1 resolution number does look a little off, but the Half D1 resolution numbers look correct (352x576 for PAL).
