PSP x9 will not run
_lifesjourney_
motherboard: Lenovo G770 Y770 PIWG4 LA-6758P
processor: intel core i5 2450 - 2.50 GHz
ram: 8.00 GB
Video Card: Intel 3000 128 - AMD Radeon 6650 128
Hard_Drive_Capacity: 500
Monitor/Display Make & Model: Lenovo G770
Corel programs: Paint Shop Pro x9
PSP x9 will not run
Post by _lifesjourney_ »
I purchased PSP x9 (not ultimate) last week. Since then I have been unable to run the program. When I attempt to run the program it shows up in the "windows task manager" for a moment then disappears. I did have a very old Jasc PSP program installed but I uninstalled it to make sure there was no program compatibility issues.
I have uninstalled and reinstalled several times.
I have attempted to "run as administrator".
I have attempted to run using [shift] to restore defaults.
I uninstalled all corel products and files including:
Corel Graphics windows shell extension
Ghostscript GPL 8.64
Any thoughts around other compatibility issues would be appreciated. It would seam the program is being blocked somewhere.
brucet
operating_system: Windows 8.1
Re: PSP x9 will not run
Post by brucet »
I haven't gone past x8 yet. But every now and again PSP will hang on start up. Administrator will show it running. The solution I have found to work is to double click on the PSP icon again. (Sometimes simply closing PSP and starting again works). This will often 'wake up' PSP. I have done a search but you should be able to find similar issues in previous posts.
Good luck.
_lifesjourney_
ram: 8.00 GB
Thank you.
Whenever I have a problem like this I open Task Manager and look in the Background Processes section. If there is an entry for Corel PSP I right click on it to end that process. Then I go back to the desktop and click on the PSP icon to restart it. This usually works.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Have you also right clicked on an image and chosen Open with PSP X9?
_lifesjourney_
ram: 8.00 GB
Yes, I have viewed the processes function and it does not appear.
I have also attempted to load the progrom by going through a picture but that does not work either. Speaking with Corel support now. I will update when I find more info.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
_lifesjourney_ wrote: Any thoughts around other compatibility issues would be appreciated. It would seam the program is being blocked somewhere.
I see you have a "500" hardrive. Gigas ?
Do you have enough place ?
Some downloaded PSP versions need an internet connection and Protexis Licensing. I don't know for X9.
Also try to desactivate your antivirus, just for verifying if something is wrong there.
Rick_R
motherboard: ASUSTeK Computer INC F2A85-V Pro
processor: AMD A6-6400K APU
Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
sound_card: On-board Realtek and AMD High Definition Audio
Hard_Drive_Capacity: 16TB+375GB
Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
Corel programs: PaintShop Pro 12-2022 Ultimate
Post by Rick_R »
Have you tried installing both the 32-bit and 64-bit versions? They both should run under 64-bit Windows.
(However, you can't run the 32-bit version and 64-bit versions of the same "X" number simultaneously. In other words, you could run 32-bit X8 and 64-bit X9 simultaneously but not 32 and 64 X9.)
Ghostscript is generally used with GIMP. It should have no effect on PSP.
Also, regarding PSP itself, there is no difference between "regular" and Ultimate. Ultimate is "regular" plus a bunch of add-ins that get installed after PSP is installed, and you don't have to install any of them. For instance, I never install the Creative Content, because that is additional brushes, tubes, etc., and since I basically only do photo retouching I never use those.
