Keep PSP Files Out Of Documents Folder
pmokover
Post by pmokover »
How can I set PSPX9 to NOT put any files in my Documents folder?
Each time I run PSPX9 it creates a folder "Corel PaintShop Pro" in my Documents folder and puts lots of sub-folders and files in it. I have no problem having that folder on my hard drive but NOT in my Documents folder. It's easy to delete but it is then re-created next time I use PSP. How can I change its location permanently?
Thanks!
Peter
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Keep PSP Files Out Of Documents Folder
Post by LeviFiction »
As far as I know, you can't. They have it hard-coded to always go to that location. You can change wher the "My Documents" folder is located, but it'll always go into that folder.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
It is possible to redirect file and directory access on Windows machines, using the mklink.exe command in a command window as Administrator (the old DOS window).
This could put a "Corel Paintshop Pro" directory link (like a shortcut) in your documents folder instead of the folder itself, that points elsewhere, even to another drive.
This means you would have the link "corel paintshop pro" in your documents directory instead of the folder, but the directory tree and files themselves would be created elsewhere.
I use links to redirect quite a bit of traffic from my small solid state drive to my large hard disk data drive. Not only the traffic, but it makes backing up data from one drive so much easier.
Just for example, I use a link to redirect the PSP "Drive:\Users\YourName\AppData\Local\Corel PaintShop Pro\17.0"
folder from my small solid state drive to my large data drive, D: in my case. This moved the PSP cache, Manager image database, RAW database and thumbnails etc. to D:\bla\bla. (You keep the "cache" under "File Locations" where it is, the link causes Windows to redirect, not PSP).
Two articles that describe it:
https://www.sevenforums.com/tutorials/2 ... ndows.html
https://ss64.com/nt/mklink.html
I'm not a Windows technician, but if this sounds like what you want, holler if I can help.
ram: 6 GB
For moving the Documents folder itself to a data drive I just use the location tab under the folder properties myself.
