Cheers, Jon
Tool Resize Problem!
- gtojon
- motherboard: ASRock X99X
- processor: i7 6850k
- ram: 64gb
- Video Card: Nvidia GTX 1080
- Hard_Drive_Capacity: 40tb
- Monitor/Display Make & Model: Samsung 55" 4k
- Corel programs: PSPX9, Video Pro X7
When I am using a crop, eraser or clone tool .... others I am sure .... for 20 years I could select the tool & resize over the image. Now when I do that it resizes the image
To me it's very important to resize the tool over the image to get the right size! Now with SP4, that is not possible! SUPPORT has been no help at all & actually closed the case because I uninstalled & reinstalled 3 times & other twisted moves to get SP4 to work. Everything work fine with SP3!
Cheers, Jon
Cheers, Jon
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Tool Resize Problem!
Same issue here. Seems to be a bug with SP4.
JoeB
Using PSP 2019 64bit
JoeB
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Do you use windowed or tabbed mode? Cassel noted that in windowed mode as soon as you hover over the image the number boxes on the tool options palette lose focus. But this does not happen in tabbed mode. This is a bug with the Service Pack 4 as JoeB noted.
JoeB
- ram: 8 GB
I use Cascade mode (which is what I assume is meant by Windowed mode). Now people using X9 are going to have to wait for SP5, which I have a suspicion we aren't going to see for a long time, if at all!LeviFiction wrote:Do you use windowed or tabbed mode? Cassel noted that in windowed mode as soon as you hover over the image the number boxes on the tool options palette lose focus. But this does not happen in tabbed mode. This is a bug with the Service Pack 4 as JoeB noted.
JoeB
JoeB
- ram: 6 GB
Yup, Windowed mode is an individual window for each image. Tabbed mode is individual tabs for each image. Since I use tabs I never saw this bug. xD
