I'm making a fairly complex educational DVD with about 20 video clips
and 25 menus.
It all worked very well in the first draft including the burned discs.
The client then made some amends, I re-streamed most of the video
clips, re jigged some menus and it all worked fine in the "Finish" stage.
But when I burn to disc I get bad links on the menus and play lists.
Menus are text only over Jpegs created in Photoshop, & my patches on
DVD Workshop 2 are up to date.
Can you help?
My menus are going wrong when I burn to DVD
Little Red Light
pauley
When you say:
I encountered problems when I modified a video and kept the same filename. Thinking DVDWS would just get the new video, and remember all of my menu links and chapter points. This does not work. By the time I had tried to pull in the mpeg as its own file, the DVDWS file was so messed up, I just had to start over.
Pauley
What did you do?I re-streamed most of the video clips
Pauley
Little Red Light
I've created dvd's with just text buttons, and they have always worked ok. But I never had to go in and change things around (like I think you did). If they worked before you modified the dvd, then perhaps it's getting confused with the modifications you ar emaking...
Try clearing out the DWS_TS Folder for your project (so it won't be able to re-use anything from prior builds).
If that doesn't work, you might have to start from scratch...
George
Little Red Light
clearing out the DWS_TS folder didn't help?
The program worked initially -- it seems that depending on the type of changes you try to apply after the fact might introduce some navigation problems (as you are seeing).
I'm not sure why, but I remember for one user clearing out the temp files helped her situation...
George
Little Red Light
