I am sharing a a Paintshop Pro X script I wrote in the last three weeks. It's called:
'Luminosity Mask Drive Thru 2.06'
It's inspired by this post and scripts:
http://forum.corel.com/EN/viewtopic.php?f=104&t=59494
See last post for the latest version.
Cheers,
Charles Bartley
cosmicDread
- motherboard: MSI MPG Z390 Gaming PRO
- processor: Intel Core i9-9900K
- ram: 32 GB
- Video Card: GeForce GTX 1080 Ti
- Hard_Drive_Capacity: 6 TB
- Monitor/Display Make & Model: Acer Predator X34
- Corel programs: PaintShop X5, X6, X8, X9, '18, '19, '20
When the majority of the people on Earth are wanting the Galactic Federation to show themselves, then they will.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
cosmicDread
- ram: 32 GB
The ‘Luminosity Mask Drive Thru 2.06' program:
What it does: The program creates luminosity masks. With a mask, one can modify an image using hue, saturation, and lightness.
Luminosity masks are useful in other applications as well (white balance comes to mind).
How to install: Copy or place the 'Luminosity Mask Drive Thru 2.06' script file in a trusted script folder.
Requires: Paintshop Pro X5+
Luminosity Mask Drive Thru 2.06 (May 21, 2019):
- Fixed a bug that occurred when the last used session file wouldn't load.
- Fixed a bug with the image not updating in Test Drive when using the arrow keys.
- Fixed an over-sight where the last used session file was updated without cause.
- Fixed a problem with the Save dialog window falling behind PSP's window.
- Windows remember their positions between sessions.
- Switched several classes to singletons for speed and simplicity.
- Updated the Main window's appearance.
- The initial Selection state is applied to the final results if the masks are merged.
The Main window looks like this: Check out my other work for art, Roller 4.7:
viewtopic.php?f=104&t=61284
I've moved the latest script updates to my Github PaintShop Pro repository:
https://github.com/gummyCowboy/Paintshop-Pro-Scripts
Best regards,
Charles Bartley
Best regards,
Charles Bartley
- Attachments
- Luminosity Mask Drive Thru 2.06.zip
- The latest version
- (26.19 KiB) Downloaded 247 times
- CB - Luminosity Mask Drive Thru v1_35.zip
- older stable version
- (17.83 KiB) Downloaded 265 times
- CB - Luminosity Mask Drive Thru 2_01.zip
- an upgrade from v1.35
- (19.38 KiB) Downloaded 237 times
cosmicDread
- ram: 32 GB
Re: Luminosity Mask Drive Thru 2.06
I am bumping this thread because the script/program was updated with improvements and fixes.
- Charles
- Charles
