As everyone knows, when one prepares to create text via the Text Tool, one would see an empty space with a flashing icon. Well, I decided to see what the Text Presets were like. Upon finishing my review of this new tool, I decided to go back to using normal text. No such luck. Everything I typed from that moment forward used Text Presets. I was forced to change all the settings in the Text Dialogue boxes to get the text back to normal. I am certain the Text Presets are still activated though, since every time I prepare to use the text tool, the very last text I created always immediately pops onto the screen. No empty blinking cursor. just the same text over and over and over again. I cannot get things back to the empty space with the blinking cursor awaiting me to enter text. I have no doubt the Text Presets tool has destroyed my defaults within the Text environment. I should like to prevent the need to uninstall the software and reinstall again to get things back to normal. Surely someone has experienced the same, and has a fix for this, yes? I would certainly appreciate anyone to give me a heads-up regarding this. If there is no one forthcoming, I shall be forced to do a complete uninstall and re-install. The Text Presets are perhaps the worst thing Corel has ever come up with, since it has caused much damage to my PSP 9.
Canuckian
DID TEXT PRESETS IN PSP 9 SCREW UP MY TEXT TOOLS?
TimW
- motherboard: ASUS M5A99FX
- processor: AMD FX8350 8 core 4.0GHZ
- Video Card: AMD Radeon HD 6900 Series
- sound_card: On Board
- Hard_Drive_Capacity: 256GB SSD
- Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
- Corel programs: PSP X8, Knockout 2
Re: DID TEXT PRESETS IN PSP 9 SCREW UP MY TEXT TOOLS?
I'm not sure about the Text Presets since I don't use them. I can help you with the last text created continually popping up on the screen. There is an icon in the Text Toolbar that turns that on & off - see the snip I did.
- hartpaul
- ram: 8 Gb
Just tested and used the Army preset. Typed some text on a transparent document and then deleted that document.
This left my Text tool with the settings for the Army preset active.
1. Opened a new transparent document
2. Selected text tool and then the presets as if I was going to use another preset. To the right second button down click that (Reset to Default), this will clear most text settings to a default set.
3. However the Army preset uses a texture so you have to double click the Background and Fill Properties box, select Texture tab and untick Add Texture. You can now select a new color, pattern or other texture.
