And so disappointed with what's new.Update 4 is now available for Corel PaintShop Pro X9. This update improves application stability and addresses a number of reported issues.
Important: This update might affect workspace customizations. If you customize your workspace, save (File > Workspace > Save) before you install the update so that you can reload the workspace later.
Please note that this cumulative update includes all the features and improvements from previous updates and hotfixes.
The build number after this update is applied will be 19.2.0.7.
The kerning bug is not fixed.Text: Can now change the font style while typing and text remains selected when choosing a font
Tabbed Documents:Images now display in tab order (left to right) as you close them
Scripts: Fixed several script errors, including stability of saved QuickScripts, and script download is now working in the 32-bit version of the application
Camera RAW Lab: Fixed Dropper tool error
Curves: Improved response to adjustments made with controls and keyboard
Paint Brush: Improved “Wet look paint” edge results and “Smart Edge” selection results
Workspace switching: Corrected issue related to switching out of the Adjust workspace
Welcome workspace: Improved response time
Vignette effect: Improved results for 16-bit per channel images
Gradient Fill Tool: Color is updated when moving a node and Opacity stop can be added from Materials palette (Standard Palette swatches)
Adjustment layer > Curves: Removed shadow artifact from results
Lens Correction: Improved lens corrections--aligned with AfterShot lens correction results
Wacom driver compatibility: Corrected random Full Screen activation
Text presets: Improved response time
Sony A7RII (ARW): Raw file preview fixed (purple fringe along edge removed)
Screenshot: Removed extra edge area from Smart Capture results and corrected image order issue when capturing multiple screenshots
Adjust workspace: Guided Tour window no longer impeded by color profile message
2-color TIFF file: Colors no longer change after saving to TIFF
Installation issues resolved for KPT, Creative Content, and Perfectly Clear
Symmetric Shape and Pen Tool: Keyboard cut-and-paste functionality restored
Pan pop-up window no longer cut off in Adjust and Effect filter dialog boxes
We need block-align text.
The About box says Copyright 2016.
Load workspace from last build works poorly on 4K.
Thanks for the improvements though. I am glad for any and all text improvements.
