Corel Video Studio Ultimate x9 Error -
Timmy127
Corel programs: Corel Video Studio Ultimate x9
Post by Timmy127 »
"An unhandled win32 exception occurred in vstudio.exe [1176]"
"Unhandled exception at 0x0000000007759768 (ulmp4lib.dll) in vstudio.exe: 0xC0000005: Access violation reading location 0x00000000333BF000."
These are the error messages I get whenever I go into the debugger whenever VideoStudio Ultimate x9 crashes. I do not know why this happens, but it happens whenever I leave the project playing in the editor for too long.
I know it doesn't "Stop working" at a certain point in the project, it will "Stop working" at different points in the project each time.
It won't crash if I play a rendered video from a thumbnail, it will only crash when playing a Project.
It also won't crash if I play a clip from the project, only when playing the Project as a whole.
And the Project in question is only 1 video clip right now, so it's not because one clip is corrupt or something.
I haven't seen anyone else have this problem with Video Studio Ultimate x9 yet. All of the other articles I can find are from people using Video Studio x4.
I also haven't changed any settings or installed any new programs on my computer since it worked last. (Which was Yesterday)
It is just suddenly not working this morning.
I hope I gave enough information that a solution can be found.
Re: Corel Video Studio Ultimate x9 Error -
I assume you are running the fully patched X9
Can you tell us what type of video files you are working with?
The ulmp4lib.dll has been a source of several problems in the past. Usually associated with Mov and MP4 type, Corel providing hot fixes as a replacement file, then we assume added the fix to the latest service pack.
The attached is one file that I have associated with a fix for 4K video, I cannot guarantee that this will cure your issue , but worth a try.
Replace the existing file ulmp4lib.dll with the attached file.
Please re-name the original to ulmp4lib_copy.dll, then paste the new file to the same location.
If things get worse, revert back to original file.
C:\Program Files\Corel\Corel VideoStudio X9
Please contact Corel Support and report this problem.
VS.zip
for CVSX9
(1.33 MiB) Downloaded 581 times
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
Very hard problem, to help you best need details of video file and project formats: resolution, bitrates, frames per second, type (mp4, mov, avi, etc). Eventually sharing a small project using Smart Package may be needed if you can't figure the issue.
Some ideas: try to reproduce reliably, try another video file, change project settings, try proxy files.
May need to uninstall, clean installation, re-install.
User for more than 10 years.
Timmy127
Post by Timmy127 »
It is an .Mp4 file with a resolution of 1280x720.
Total Bitrate: 1214kbps
Data Rate: 1088kbps
Framerate: 30fps
Audio Bitrate: 125kbps
Audio Channel(s): 2 (Stereo)
Audio Sample Rate: 44kHz
Timmy127
Post by Timmy127 »
lata wrote:Hi
VS.zip
It is a .Mp4 video with a resolution of 1280x720 and a total bitrate of 1214kbps.
When I used the file it didn't fix it, and the problem remained the same, the only difference is that it crashes automatically and says: " The instruction at 0x000000000779A2DB referenced memory at 0x00000000238C6000. The memory could not be read."
I will be reverting back to the old ulmp4lib.dll.
Well I guess it was worth a try.
Can you make sure your project properties match your video files properties.
As Al asks, a Smart Package of your project may help as we can try your files on our pc,s
Maybe we can replicate the problem.
You would have to upload to a sharing site, Google drive, Dropbox etc.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
I don't think it's related but that bit rate is terribly low for 720, and so the quality.
I export 90+min 720 at 2Mb as the bottom of the barrel quality.
Panasonic X900m, VXF1
aljimenez
ram: 24GB
Post by aljimenez »
Don't go back to the original dll file since you now have a reproducible failure. See my other ideas; one namely, try another video file to see if it also fails this may point to the current video file as the culprit. For sure that bitrate means very poor quality video as asik says, but the program should not fail like you are experiencing. What are your Project settings?
Kempshott
motherboard: Gigabyte GA-H110M-S2H
processor: Intel i5
Video Card: AMD Radeon RX 460
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10
Post by Kempshott »
I get exactly the same problem with X10 @SP1 playing back MP4 files (1920 x 1080 24fps) captured on a Panasonic GH4.
Last month after logging a fault with Corel, a support chap connected remotely to my PC, saw the crash and fiddled with the proxy settings. That seemed to fix it for the short sample videos I'd been testing, but now I'm back from holiday with longer clips the problem is back.
Usually it crashes about 8 seconds before a transition, but not always.
The Event log entry is:
vstudio.exe
20.1.0.14
58de2730
ulmp4lib.dll
20.1.0.14
58de0a21
c0000005
0000000000072302
23b0
01d2cfca4edec9bc
C:\Program Files\Corel\Corel VideoStudio X10\vstudio.exe
C:\Program Files\Corel\Corel VideoStudio X10\ulmp4lib.dll
43bd18b1-269f-463a-8472-e87173611df8
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
another error for the archive.
I'm just setting up my new system , and installing X9, and SP2
So far so good,
But I did recall that a new ulmp4lib.dll was issued few months ago
So I replaced it.
But now X9 wont run , it crashes with this error
APPCRASH
Application Name: vstudio.exe
Application Version: 19.2.0.4
Application Timestamp: 570e478d
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.17514
Fault Module Timestamp: 4ce7c78c
Exception Code: c06d007e
Exception Offset: 000000000000a49d
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1037
KERNELBASE.dll is a windows dll, so I switched back to the original ulmp4lib.dll file and now X9 (so far) do not crashes
Kempshott
processor: Intel i5
Post by Kempshott »
I'm on X10 - none of the earlier ulmp4lib.dll's out there work for me either.
My crashes seem to be much worse if I have transitions (I use crossfade by default) between clips - it invariably crashes about 6 seconds before a transition. With no transitions I can (usually) Edit and Share a project.
Hi Kempshott
None of the hot fixes were intended for CVSX10, I doubt they will help, and maybe make things worse.
I suggest you revert to the original file.
Can you start a new topic regarding the crashes you are experiencing, describe your video files, their properties may help, and what you are doing when the crashes occur.
That way this post will remain for the X9 errors.
Kempshott
processor: Intel i5
Post by Kempshott »
Well I would start a new thread but -in desperation I've just changed my video card from an nVidia GT 730 to a Radeon RX 460 and everything works perfectly now.
moviloader
motherboard: LENOVO SKYBAY SDK0J40709 WI
processor: Intel Core i7-6700 CPU 3.40GHz
ram: 16384 MB
Video Card: NVIDIA GeForce GTX 1070
sound_card: ASUS MG279-4 NVIDIA High Definition Audio
Hard_Drive_Capacity: 1.5 TB
Corel programs: VS x9
Post by moviloader »
I have the same issue and have tried the hotfix (VS.ZIP) aswell, it does not work, it crasch when i add an transition. What i found out was that if i rename the MP4 file to .MOV everything works fine. When i try the new x10 version the .MP4 files work fine. It is clearly an issue with the ulmp4lib.dll in x9. I work with Panasonic GH5 and there 8 bit FHD format. see below
File data from MediaInfo.
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/avc1)
File size : 45.0 MiB
Duration : 3 s 840 ms
Overall bit rate mode : Variable
Overall bit rate : 98.3 Mb/s
Encoded date : UTC 2017-11-20 21:52:09
Tagged date : UTC 2017-11-20 21:52:09
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 96.3 Mb/s
Maximum bit rate : 106 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
