Error code: No burner exists
tjjem
motherboard: Quanta 363C 36.16
processor: Intel Core i7 Q 720
ram: 6GB
Video Card: NVidia High Definition
sound_card: IDT High Definition Audio CODEX
Hard_Drive_Capacity: 450 GB
Monitor/Display Make & Model: Nividia GeForce GT 230M - Generic PnP monitor
Corel programs: VS 12, VSX4, VSx8
Post by tjjem »
I finished a new project in my X9.5 ultimate version and when I went to burn it I get an error response stating: No burner exists
I have done diagnostics on the burner, drivers are the latest I even restored the computer back to two days earlier before I installed the lastest update for videostudio (since a pop-up suggested I update the last time I closed out of it). It recognizes everything about the drive (showing how much space is on disk, etc) and even momentarily starts the burn then jumps to the error code [516:0:0] No burner exists.
Any ideas why it is suddenly doing this. Do I need to uninstall some random windows update again like last year??????
Thanks for any help you can give me.
Jana
Re: Error code: No burner exists
Sorry for the delayed response. Are you still having this problem? If so then let's see if this may help. If not, then ignore this. ;)
I'm not sure what that error code is really saying. By your post VS does recognize your burner, so by that the error is in error if you know what I mean. So anyway, here's some suggestions to see if it helps you get past that.
1. You didn't say if you went directly into the burn module from the project (Share>Create Disc). If so try rendering your project first, to the correct file format, DVD Compliant MPEG-2. Once you've rendered your project, save it. Then choose File>New Project or Press CTL+N, this is merely to clear the timeline. From there go to Share>Create Disc to open the Burn Module. In the Burn Module you will insert the video file you created from your project, proceed on with the building the menu(s) ect, to the Burn step, to see if you can now burn your disc.
2 What you also might do instead of burning a disc, is to create DVD Folders. That way if something happens you're not creating coasters instead of DVD video discs. If this is successful, you can then create the disc, by burning, (copy/pasting) those folders and files onto a DVD.
3. Have you tried using a different DVD Disc? Perhaps there's some defect with the blank, and VS is throwing the error because of it.
John-T-Smith
motherboard: ASUS Sabertooth
processor: Intel i7
ram: 32 Gig
Video Card: nVidia GTX760 2Gig
sound_card: Motherboard
Hard_Drive_Capacity: 1152 4SSD
Monitor/Display Make & Model: Samsung P2770
Corel programs: VSX9 (19.5.0.35)
Post by John-T-Smith »
Do you have any other disc burning software installed?
I've read other messages that say that a "quick burn" type of program (where your drive is "tricked" into acting like a hard drive so you can simply copy files to the drive and the quick burn program will write them to disc) can cause communication problems with other programs being "locked out" of taking control of the burner
Canon SX510 HS - MOV H.264 24bit color 1280x720 29.97 fps LPCM 48khz audio
All SSD - 256Gig Boot + 256Gig Temp + 512Gig Input + 128Gig for all Output
Grass Valley ADVC 110 via Firewire IEEE1394 cable to convert analog to digital
