Adding Sound Effects to Transitions
SolidSnake2003
motherboard: PEGATRON CORPORATION Narra6 6.01
processor: AMD Athlon x2 240 Dual Core Processor
ram: 3GB
Video Card: NVIDIA GeForce 6150SE nForce 430
Hard_Drive_Capacity: 500GB
Post by SolidSnake2003 »
Is there any good tutorials on how to time sound effects with transitions using corel video studio?
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Adding Sound Effects to Transitions
Post by asik1 »
SolidSnake2003 wrote:Is there any good tutorials on how to time sound effects with transitions using corel video studio?
Hi, what tutorial you need?
Just drag the effect (to sound track) where the trans time.
( personally I hate that on TV)
Panasonic X900m, VXF1
SolidSnake2003
ram: 3GB
I was just wanting to learn how to time it correctly. Whenever I do it, the sound doesn't work with the transition.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
SolidSnake2003 wrote:I was just wanting to learn how to time it correctly. Whenever I do it, the sound doesn't work with the transition.
So? move it few frames
You could add a cue point above the top timeline to a position on the video, then switch to audio view will show the audios wave form, should help in lining up the clips
OBB
motherboard: Dell XPS Studio 8900
processor: 6th Gen i7-6700
ram: 32Gb
Video Card: EVGA GeForce GTX 680 4Gb
sound_card: RME RayDat
Hard_Drive_Capacity: 6Tb
Monitor/Display Make & Model: Multiple
Corel programs: Painter15/Paintshop-pro/Sketch
Post by OBB »
Yep! move them forward/backward incrementally, or, frame by frame as needed...
I've also found over the years, that when working with audio, If I find a 'problem audio (or video) snippet' that still refuses proper alignment. on occasion, if you split and cut frames (or sometimes seconds, depending if you have silence at the beginning) can also really help finicky clip alignments...
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
Have you tried scrolling along the timeline to the start of the transition and noting the time code, then do the same at the end of the transition.This will give you frame accurate times.Position the timeline cursor at the start of the transition then drag the audio to the start of the transition where the white veritcal line is.Then move the cursor to the end of where the transition is.Cut the audio clip at this point and delete the unwanted portion.If you enter the time code value the cursor will jump to that precise point.Depending on the length of the transition you could also consider fading the audio in and or out.
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Post by Terfyn »
Another trick is to hold the Shift key when clicking on the end of an audio track and moving it to align with your video. What this does is to "stretch" or "compress" the audio track without cutting it. The audio is speeded up or slowed down depending which way you pull the track. This works well for small changes in track length and makes it easy to align a complete piece of music with a video sequence.
