Capture from camcorder does not work
kafka
operating_system: Vista Business
Hard_Drive_Capacity: Denistone
Post by kafka »
I am using VideoStudio Pro X4 which I have used successfully for several years. I have been trying to capture video from my Sanyo camcorder but with strange results. after an hour or more of capturing I end up with four audio files and one video file (uvs170307-001.mpg) but no actual video appears and there doesn't seem to be anyway of seeing the movie. I have attached a file describing the video details. Note also that I specified PAL but the video is in NTSC format. Corel Support can't help me because hey no longer support this version af VideoStudio Pro. In the past I haven't encountered this difficult.
ALSO: I have been experiencing difficulty in opening the program. Although I have uninstalled and re-installed it several times I get the error "Corel has encountered an unspecified error and will close". Although I successfully installed it this morning and captured video as per the above, the next time i tried to open it I got the above mentioned error message. Should I abandon VideoStudio Pro X4?
John-T-Smith
motherboard: ASUS Sabertooth
processor: Intel i7
ram: 32 Gig
Video Card: nVidia GTX760 2Gig
sound_card: Motherboard
Hard_Drive_Capacity: 1152 4SSD
Monitor/Display Make & Model: Samsung P2770
Corel programs: VSX9 (19.5.0.35)
Re: Capture from camcorder does not work
Post by John-T-Smith »
Which operating system, and have you done an operating system update between working and not working?
Canon SX510 HS - MOV H.264 24bit color 1280x720 29.97 fps LPCM 48khz audio
All SSD - 256Gig Boot + 256Gig Temp + 512Gig Input + 128Gig for all Output
Grass Valley ADVC 110 via Firewire IEEE1394 cable to convert analog to digital
What type of Sanyo camcorder?
You mention capturing over an hour, so I assume a tape based cam, maybe Mini-DV
Can you give details
Also --- how are you connecting the can to pc, if it is MiniDV you should be using Firewire IEEE Connection?
kafka
Post by kafka »
I am using Windows 8. I haven't done an operating system update recently, though a considerable time has elapsed between its working and not working. My Sanyo camcorder is ac Xacti AVC/H264. I connect the camera to the computer via USB. The camera is neither tape based nor miniDVD, rather it uses a 16gb memory card.
canuck
operating_system: Windows 8.1
Post by canuck »
kafka wrote:I am using Windows 8. I haven't done an operating system update recently, though a considerable time has elapsed between its working and not working. My Sanyo camcorder is ac Xacti AVC/H264. I connect the camera to the computer via USB. The camera is neither tape based nor miniDVD, rather it uses a 16gb memory card.
You should not require to capture from the memory card. Simply use Windows Explorer and copy the video files from the memory card to your hard drive.
I am assuming that Windows Explorer sees the memory card as an external device.
