Filter - Fade to Grey
dumbdumber
- motherboard: ASUSTek Computer inc
- processor: 3.10g Intel Core i3-2100
- ram: 4gb
- Video Card: nvidia
- sound_card: realtek ac97
- Hard_Drive_Capacity: 477gb
- Monitor/Display Make & Model: Philips 223e
I'm using x9 Ultimate. I want a video clip to start off in colour, then gradually fade to monochrome. Please help.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Filter - Fade to Grey
Hi, when was the last time you looked at the hue and saturation FX?dumbdumber wrote:I'm using x9 Ultimate. I want a video clip to start off in colour, then gradually fade to monochrome. Please help.
Panasonic X900m, VXF1
dumbdumber
- ram: 4gb
I was looking at the monochrome which didn't give me the options i needed. Thanks aski1
I have always found the easiest way to fade to any colour is to drag the colour block you need from the 'colour' library down onto the end of the clip and apply a cross fade transition.
Terfyn
- motherboard: ASUSTeK P8H61-MX
- processor: Intel Corei5-2320
- ram: 8Gb
- sound_card: NVIDIA High Def Audio
- Monitor/Display Make & Model: Acer & LG
- Corel programs: VS X10 and PSP X8
To follow on with Brian's recommendation. Get either a snapshot or a clip of the shot and put on the main track, add the same clip next to the first to get two clips exactly the same next to each other.
Open the second copy of the clip and, with Options, reduce the Saturation to zero. You should now have two clips of the same shot, the first in colour and the second in black and white. Now insert the "Crossfade" transition between the clips and, if you wish, extend to give the length of transition you require.
A second method which works with video. Get same clip and drag one copy on to the Main Timeline then drag the same clip on to the Overlay track below the first clip. Set the Overlay to fill the screen. Now open the Options and reduce the saturation of the clip on the Overlay track to zero. Click on the Fade-In option and run the clips as a Project.
dumbdumber
- ram: 4gb
Thanks Terfyn, that second method was the most succesful.
