I'm using Videostudio X9.5 and am exploring the menu creation process. I started with a project containing three clips and created chapters, one for each clip. All was fine and I saved the project.
Later, I decided to add another clip to the project and went through the menu chapter creation process again starting from scratch marking each chapter. When I get to the point where I want to title the chapters, I see the original three chapter text placeholders - "chapter 1", "chapter 2", "chapter 3". There is no "chapter four". The program should create a placeholder title for each chapter that I create - so why is it refusing to show the fourth?
Also, I note that I can hide elements of a menu, but I see no way to restore them once I have hidden them. What's the trick to bringing back things that have been hidden?
X9.5 added a clip and chapter, but menu won't add the title
Re: X9.5 added a clip and chapter, but menu won't add the t
I am not sure that you understand the difference between adding a clip which creates a title - or adding a chapter which you can do to a title
a title is what you get when you add a video clip to the timeline in the create menu / DVD burning module - this may be divided - by you into chapters which will appear on a separate menu page - - chapters are created by you and apply to individual video clips and basically split the clip
if you are just adding a clip to the menu (by importing the clip direct in the create menu module) then you do not need to also add a chapter for it to show on the menu
having said that - did the menu you chose to customise only start with 3 placeholders - if yes then VideoStudio would create a page 2 in the menu to hold the fourth one - check the little drop down immediately under the preview screen - is it 'live' and showing options to view another page
have a look at this video - https://www.youtube.com/watch?v=WmvWu0lw6G4 - I made it in X5 so the start is slightly different but once the 'Create menu/burn Disc' window opens then it is the same as current versions
if you have hidden an object then hover over the location where it was - the yellow boxes should still appear so that you can right click and unhide the object
clif9710
- processor: I7 - 3rd gen
- ram: 16g
- Video Card: Nvidia GTX 1060
- Hard_Drive_Capacity: 1tB SSD
Brian - you've answered not only the questions I had, but provided context that answered others I've had as well.
Thanks very much!
Thanks very much!
John-T-Smith
- motherboard: ASUS Sabertooth
- processor: Intel i7
- ram: 32 Gig
- Video Card: nVidia GTX760 2Gig
- sound_card: Motherboard
- Hard_Drive_Capacity: 1152 4SSD
- Monitor/Display Make & Model: Samsung P2770
- Corel programs: VSX9 (19.5.0.35)
I made my 1st (so far only) DVD last fall and find the people here to be VERY helpful, next one will be later this year after we go on vacation
Canon SX510 HS - MOV H.264 24bit color 1280x720 29.97 fps LPCM 48khz audio
All SSD - 256Gig Boot + 256Gig Temp + 512Gig Input + 128Gig for all Output
Grass Valley ADVC 110 via Firewire IEEE1394 cable to convert analog to digital
