Add texture to a layer
pdxrjt
processor: Intel Core i7 - 4.2 GHz
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1080
Hard_Drive_Capacity: 10TB Int.
Monitor/Display Make & Model: Acer 32 inch x2
Corel programs: Paint Shop Pro 2018
Post by pdxrjt »
I thought I had this down. Apparently not. I have a layer in a color I like (tan) with multiple smaller layers on top of it. I am trying to add a texture (probably canvas, but am currently using brick so I could see if there was an affect.) I have the base layer (the plain tan one) highlighted. I open the paint can tool (flood fill.) In the Materials Properties Box, I click on the foreground color (the tan used in the base layer), click on the middle (textures box), then up in the tan colored window. The texture tab shows up and I click it, then select brick. This is the foreground color box. Then I put the flood fill tool on the highlighted layer and click..... nothing happens. No texture. How do I add texture to the color in the base layer? TIA
Adverts for Corel products when you close PSP don't bother me.
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Add texture to a layer
Post by Kathy_9 »
You can go to Effects -> Texture Effects -> Texture, select the texture you want and make adjustments.
pdxrjt
ram: 32 GB
Post by pdxrjt »
Thanks that worked great. Are the help files broken? I tried those first and after I clicked on them (from within PSPx9) nothing happened.
Kathy_9
Post by Kathy_9 »
You're welcome. Help files working okay for me.
