I am presently using VS 9.5 ultimate and am trying to record an edited video I have made. I am trying to record it using MPEG-4 AVC(1280 x 720, 25 p, 10Mbps). The rendering starts normally but at about the half way stage it comes up with a box stating it only works with Windows 7, 8 and 10. It then stops the whole thing. I am using Windows 10 on a MSI Apache Pro computer and so do not know the problem.
I have tried recording this clip 3 times at different MPEG-4 settings and get the same result. Playing the video in edit mode it is working correctly. The last time I tried to record I sat and watched it and found it stopped at 67%. I then edited again and cut out a section with 3 minutes either side of this point and tried to save that to MPEG-4. This worked perfectly, I then tried recording the whole file again and once more it stopped rendering at 67%.
Can anyone help?
Not recording MPEG-4 AVC
mikeandm
- motherboard: Micro-Star International Co MS-1795
- processor: Intel Core i7-6700HQ CPU
- ram: 3936
- Video Card: NVIDIA GeForce GTX 960M
- sound_card: Realtek High definition
- Hard_Drive_Capacity: 1233GB
- Monitor/Display Make & Model: Generic PnP moniter
- Corel programs: Videostudio 22
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Not recording MPEG-4 AVC
I must look more carefully what you have at the ~67% point and correct it.
Panasonic X900m, VXF1
mikeandm
- ram: 3936
I tried what you suggested by going into the original file and cutting out a 5 minute section centred on 67%. I then put in the same clip which I had previously recorded as a MPEG-4 file. This clip I had tested using VLC and it played perfectly. After installing the new clip I then tried to render using MPEG-4. This time it stopped after 68%, this was within the range of the new clip I used.
Unfortunately I have now run out of ideas.
asik1
- ram: 8gb
the fact that VLC plays it, means nothing if VS still can't.
is this 5 min section is a single clip?
mikeandm
- ram: 3936
It was several clips which I had edited as part of the complete file. I then just copied the 5 minute clip into a new project and saved that. I then went back into the original clip, cut out the section and inserted the new section. That is the one that I then tried to save the last time.
I would add that if I run the whole file in edit mode everything is playing OK, that is the complete file which is about 50 minutes and the new 5 minute clip which I have saved as MPEG-4. I have also saved it as an AVI file as a test and that works fine as well. It is only when I try to render that it stops and does not recognise windows 10.
Tomorrow I think I shall save just the first 30 mins and then try the second half seperately to see if the file is too big.
Will let you know the result.
mikeandm
- ram: 3936
OK,I have tried saving the large file into two clips. The first worked fine the second stopped at about the same point once again. I have just downloaded the VS 10 trial so I tried with that and got the same results.
My next effort was to take a larger section around the problem area and tried to record that. That section rendered perfectly without me altering any of the settings.
I then cut and pasted the new clip I had made into the original file and rendered it once more.
This time it worked perfectly. I still do not know what was causing the problem since I have only used a small bit of the original file, saving that bit and then incorporating it once more. Does not make sense to me, but at least it has worked and I can now play the whole clip as a MPEG-4 file.
