Cropping in X8
zhunter71
ram: 8gb
Cropping in X8
Post by zhunter71 »
I have just switched to X8 from X6, and when i select the CROP button, the image zooms out so the whole image is in view, how do i stop it doing this? It didnt used to do this in X6, when you selected CROP it used to leave whatever view you had on the screen unaltered, its a bit annoying cos if i want to crop the bit i am already zoomed in on i have to zoom in again to it and hitting the CROP button ! i cant see anything in the preferences to change this? thanks!
LordLiverpool
motherboard: Intel CM238
processor: Intel Core i7-7820HK
Video Card: nVidia GeForce GTX 1080
Re: Cropping in X8
Post by LordLiverpool »
Yeah, I tried X8 and this change infuriated me. It's a case of software trying to be clever and help you, when in fact it just gets in the way. With large images, you often need to fine-tune the cropping rectangle by zooming because the image is too large to see exactly where the rectangle's edges are.
This one change alone makes X8 unusable for me.
zhunter71
ram: 8gb
Re: Cropping in X8
Post by zhunter71 »
i've gone back to X6.....this one issue and a few other small changes make me prefer and work much faster on X6 :D
TimW
motherboard: ASUS M5A99FX
processor: AMD FX8350 8 core 4.0GHZ
Video Card: AMD Radeon HD 6900 Series
sound_card: On Board
Hard_Drive_Capacity: 256GB SSD
Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
Corel programs: PSP X8, Knockout 2
Re: Cropping in X8
Post by TimW »
That is very strange. I have & use X8 and it does not zoom out as the OP described when using the crop tool.
I did some experimenting & have been able to reproduce the zoom out effect by . . . . Selecting the Pan Tool, zoom in with the mouse wheel, Select the Crop tool, then do the crop.
My solution . . . Do not use the Pan tool. Select the Crop tool, zoom in as desired with mouse wheel, do the crop. It holds for me. If re-positioning the image before cropping is necessary, use the sliders. I also uncheck <automatically display crop rectangle> in <Preferences> <Display & Shading>.
LordLiverpool
Re: Cropping in X8
Using the mouse wheel is a good solution - I admit I didn't know you could do that.
You can also zoom in using the menu.
What this change breaks is the combination of zoom tool and crop tool - you can't change between them. I suspect that the programmers only use the mouse wheel and never considered that people might use the zoom & crop tool in combination.
LordLiverpool
Re: Cropping in X8
In any case, it's still absolutely wrong to zoom out without giving the user the option to deactivate this behaviour. Who says I want to see the whole image to crop it? What if I'm already zoomed in on the part I want to crop?
