Apply auto transition effect to part of project
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
In X9 I have 80 jpegs in the middle of a project that I want to insert a cross fade transition in between. Is there a way of auto inserting but only affect these jpegs and not the rest of the project ?
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Apply auto transition effect to part of project
Select them all and apply.Ken Veal wrote:In X9 I have 80 jpegs in the middle of a project that I want to insert a cross fade transition in between. Is there a way of auto inserting but only affect these jpegs and not the rest of the project ?
Panasonic X900m, VXF1
Ken Veal
- ram: 32 GB
Think I need more information .If I select all the jpegs and then go to the crossfade transition to right click it and select “apply current effect to video track” the jpeg selection is cancelled. Am I not trying to do what was suggested? What should I be doing ?
Hi Kenneth
As far as I know you can apply transitions individually or all, but not a selection
You could set F6 preferences transition settings, auto apply
Drag the images to the library as a copy
Delete the images from time line, then add images again, should apply the transition,
First I would save your project as a copy, as a backup
Terfyn
- motherboard: ASUSTeK P8H61-MX
- processor: Intel Corei5-2320
- ram: 8Gb
- sound_card: NVIDIA High Def Audio
- Monitor/Display Make & Model: Acer & LG
- Corel programs: VS X10 and PSP X8
Would it be possible to add the jpegs to an overlay track and insert the transitions there?. The main video track could have a black graphic inserted to match the location of the jpegs.
asik1
- ram: 8gb
Sorry, you are correct, it was my mistake.Ken Veal wrote:Think I need more information .If I select all the jpegs and then go to the crossfade transition to right click it and select “apply current effect to video track” the jpeg selection is cancelled. Am I not trying to do what was suggested? What should I be doing ?
I keep thinking that VS can be clever enough to do such relevant task but unfortunately VS is stupid.
Ken Veal
- ram: 32 GB
Would this be an appropriate issue for the next version wish list ?
asik1
- ram: 8gb
Indeed, but unfortunately I guess the wish list so far, is as long as the unsorted bugs list so what to do first?Ken Veal wrote:Would this be an appropriate issue for the next version wish list ?
Ken Veal
- ram: 32 GB
If it is of any help to anyone this workflow worked for me,thanks for the advice gentlemen
1 F6- Preferences-Edit tab
2 Set default photo duration
3 Set default transition effect duration
4 Select default transition effect via drop down arrow
5 Check automatically add transition effect
6 Add cue point at start of 1st image in timeline
7 Select and drag all images to library
8 Select and delete all images in timeline
9 Select all relevant images in library and drag back to timeline cue point
10 Images show with chosen transition, length and transition duration effect
11 Return to Preferences and reset selections
Hi Kenneth
Well Done
Well Done
