Work with mask in VS X9
Potapov14
Post by Potapov14 »
I have video on 50% of screen. I have circle mask.
I need move (from left to right) video, but mask need be all time on the center of screen.
I can create mask but it apply/attached only for video, not for all screen.
How can I solve it?
Re: Work with mask in VS X9
Post by BrianCee »
hello
how do you use the mask
do you put it in the overlay track like this
Potapov14
Post by Potapov14 »
Yes, but I want, that digit "2" will move from left side of screen to right, but circle (mask) stay on centre.
Post by BrianCee »
if the video moves it will work as I show - is the problem that you video does not move
Potapov14
Post by Potapov14 »
Did You use Chroma Key on black circle? Or use mask frame?
Post by BrianCee »
it is a mask frame which I made - no chroma key
watch this video - is it what you want - - - https://youtu.be/t7LIJk_WHYo
download this zip file - - - unzip it to obtain the mask file I used - put it in your VideoStudio overlay track
transparent circle coloured.zip
(15.85 KiB) Downloaded 201 times
Potapov14
Post by Potapov14 »
hm... it is transparent circle, it works without any overlay. It is easy. I want next effect, I drow it on paper:
1) first layer it is "background 1" static
2) second layer it is "background 2" dynamic (move from left to right)
3) mask. I can see throught circle with "background 2" on "background 1".
Post by BrianCee »
OK - another attempt
note that the background '1' in the top track can be any video or photo
also background '2' can be any video or photo and move at whatever speed you wish
watch video here - - https://youtu.be/chHg8XmLcDM
Potapov14
Post by Potapov14 »
I see, but I do not want to see blue background. Only landscape (layer 1) and baloons (layer 2) But when ballons movei from left to right, it will be appear throught circle mask (from transperend backgroun, I will not see blue color)
Potapov14
Post by Potapov14 »
I tried many variants, and if this function is absent do not worry, maybe this task for professional software.
Post by BrianCee »
OK - no blue color
I don't know about more professional software - we need a more professional specification to work to
OK last attempt if this is not what you mean then you will have wait and see if someone else can understand what you want and tell you how to do it
final video on this subject - -- --- -- https://youtu.be/V8UunCLldUg
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Correct Brian,
That is exactly what I did while you posted
But potov, the mask need to be reversed, black on white.
Panasonic X900m, VXF1
Potapov14
Post by Potapov14 »
Thank You for response and answers! I done my home video! This topic is solved!
