I'm trying to install a trial version of PSP X9 and at 33% during the installation portion of the download and install process, I get the message in the title of this post. I have tried every suggestion I can find, even deleting everything in the registry referencing Jasc, Paint Shop, Corel or Ulead.
Running the installation as administrator doesn't work.
Turning off antivirus (Norton) auto-protect and smart firewall doesn't work.
Manually creating a programdata folder and trying to take possession of it doesn't work.
I can't find the downloaded files to delete them and start over despite looking in every temp folder, so the dialog box shows "continue the installation."
Thanks!
"We encountered a problem while installing"
edwardBe
- processor: Intel core i5 6200U 2.3GHz
- Video Card: NVIDIA 940MX
- Hard_Drive_Capacity: 250GB SSD
- Monitor/Display Make & Model: Acer Aspire E 15 E5-575G-53VG Laptop, 15.6 Full HD
- Corel programs: None. PSPX9 trial.
edwardBe
Re: "We encountered a problem while installing"
For anyone else who has this problem, these are the instructions I got from Corel that worked:
1. Disable the User Account Controls
http://winaero.com/blog/how-to-turn-off ... indows-10/
2. Turn off your Anti-virus / Firewall application.I forgot to do this but it worked anyway.
3. Turn off all Startup applications
http://www.howtogeek.com/74523/how-to-d ... n-windows/ I used the task manager method.
4. Clear out your Temp folder:
Hold down the Windows and 'R' keys on your keyboard
Type the word: appdata into the run box and click the OK button
Open the Local folder
Open the Temp folder
Delete the items in the Temp folder
5. Retry the install as an administrator.
scottb613
- motherboard: Gigabyte
- processor: i7-7700K Kabylake OC 5 Ghz
- ram: 32GB
- Video Card: EVGA GeForce GTX 1070 Ti
- Hard_Drive_Capacity: 2000 GB
- Corel programs: Jasc PSP 9.1 - now PSP x9
Hi Folks,
RE: Win10x64
First post - long time PSP user - still using Jasc PSP 9.1... Wanted to see what was new with Corel - so I downloaded the demo and am unable to install it... It may have stopped the first time at 30% but now it stops at 88%... Some error about "not being compatible with my system" - like maybe a 32 bit vs 64 bit thing ??? Same issue as original poster - I can seem to reset everything for a clean run... The downloaded install files are hidden somewhere and the installer just tries to use the same files over and over without downloading anything new... I've purged all temp directories I am aware of - deleted the installer - deleted the files installed - cleaned the registry - no joy... Every subsequent run starts - goes to around 5 % then jumps all the way to 75% and progresses until it hits 88% and permanently freezes... I've been completely unable to get a clean start on this...\
I tried the steps mentioned above - no joy there as well...
This isn't inspiring confidence in spending money on an upgrade...
Help ?
Thanks...
Scott
RE: Win10x64
Help ?
Thanks...
Scott
scottb613
- ram: 32GB
Hi Folks,
Just to follow up...
Support supplied me with a tool to clean and remove all traces of of PSP from my machine... Worked like a champ...
Support also supplied an installer with all the necessary files contained within the installer - no additional downloads during install process - also worked like a champ...
All set now - thanks...
Scott
Scott
cdkscully
- processor: AMD FX 6300-Core Processor 3.50GHz
- Hard_Drive_Capacity: 2TB
Did they have to log into your computer to do the setup? I have a support person stating that he needs to remote into my computer to assist with this errorscottb613 wrote:Hi Folks,
Scott
Chris.
- flagpole
- motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
- processor: Ryzen 2600
- Video Card: RTX 2060
- sound_card: on board
- Hard_Drive_Capacity: 6.5TB
- Monitor/Display Make & Model: Iiyama 27"
You're sure that they're actually from corel? You called them? on the official number?
I would be very cautious about about letting someone do this to my computer. I'd ask them to talk me through it.
