Text and shape cutter tool
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
Text and shape cutter tool in X8
I have tried to follow a tutorial found here-http://learn.corel.com/tutorials/text-a ... tter-tool/
• and got as far as “Re position the text with the pick tool and apply a layer style by double clicking on the layer” near the end
• It then goes on to state “Add an outer glow to make the text stand out”
• But I cannot clearly see how they describe how to do this- can someone explain please
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Text and shape cutter tool
Post by LeviFiction »
When you double click on the layer it should bring up the Layer Properties dialog. If you don't get this, right-click on the layer and select "Properties".
Inside the Layer Properties dialog click on the "Layer Styles" tab. You'll see several possible layer effects on the left hand side. To turn one on click on the checkbox next to the effect name. In this case "Outer Glow" this places a soft edge of any color you want around the layer. Select the Outerglow text as well to see the outerglow options. You can then adjust the size, and opacity of the glow to fit your tastes. In the video they show decreasing the size of the outer glow. use the color box to change the color.
