*Still* no thumbnails for ".pspimage" files - Windows 10.x
mounsey
ram: 24GB
Video Card: GeForce GTX 1050
Monitor/Display Make & Model: DELL 4k 24"
Corel programs: Corel PaintShop Pro 2020, CorelDraw
Post by mounsey »
Hi all-
First of all.. I *have* checked (scoured!) this forum in case there was already a fix (and one that actually worked..) for this issue - but alas, I cannot find one.
The issue is simple: I (still) cannot see / never get thumbnails for ".pspimage" formatted files on my Windows 10.x system (64 bit, latest stable "build" etc.).
I'm on the 64 bit version of PaintShop Pro X9 - and believe I have the latest patches etc. installed.
However, I can't recall getting / seeing thumbnails for pspimage files on *any* recent build / version I've had.
Now, I know this could well be Windows 10.x to blame - I appreciate and understand that. However.. despite bad press elsewhere, I personally have had little or no issues whatsoever with Windows 10.x.
Except for this!
So.. I guess my initial question is a simple one: Does anyone else have this same problem?
(and if "Yes", have you managed to solve it? I'm reluctant to uninstall PSP X9 as I am otherwise very happy with it - and what's more I'm pretty sure I've given this a try already (with no success).).
I'm also certainly not planning on touching Windows 10 - as again it's fine on everything else (and no plans to delve into the Registry either!!).
Help me.. someone! It's amazing just how much productivity I feel like I'm genuinely losing by simply no longer being able to see thumbnail images for .pspimage files :( (which I use all the time..).
Cheers,
John.
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: *Still* no thumbnails for ".pspimage" files - Windows 10
Post by Forriner »
If you mean the Windows file explorer, have you tried rebuilding the thumbnail and icon caches? You have to delete existing caches first, then Windows can rebuild them, hopefully correcting any database corruption.
http://www.thewindowsclub.com/rebuild-i ... windows-10
Good luck.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
As asked above, are you not seeing them in Windows File Exlporer, or is it in PSP's Manage tab, or both? If only the first, why not use Manage mode to explore the folders instead of Windows File Explorer?
JoeB
Using PSP 2019 64bit
TimW
motherboard: ASUS M5A99FX
processor: AMD FX8350 8 core 4.0GHZ
Video Card: AMD Radeon HD 6900 Series
sound_card: On Board
Hard_Drive_Capacity: 256GB SSD
Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
Corel programs: PSP X8, Knockout 2
Post by TimW »
I believe this is what you are looking for. . . PSP Handler Setup from Bot Productions. Info & Download from this site - http://www.botproductions.com/pspthumb/overview.html
mounsey
ram: 24GB
Post by mounsey »
Thanks for the responses so far. Must admit I hadn't considered the Windows icons cache, as didn't realise that could still be an issue with 10.x.
I'll try that first and report back with my findings!
Cheers, John.
mounsey
ram: 24GB
Post by mounsey »
OK.. so I've tried something different first - using this:
(which went through OK.. but no change post reboot - see below):
The result (no change, post reboot)
Is using the Windows built-in "Disk Clean-up" tool (and this option) the same as amending / deleting those "Cache" files as one or more earlier replies suggested?
Nb. See how all is OK on image #2.. *except* for the ".pspimage" files (still).
John.
Forriner
ram: 16 GB
Post by Forriner »
I've never had problems with Windows and PSP, so it's just trying things out.
In that dialog, you cleared Thumbnails, but does that also clear Icons?
You'll find Thumbcache_*.db and Iconcache_*.db files in: Drive:\Users\YourName\AppData\Local\Microsoft\Windows\Explorer.
Again, just trying things because it should not be necessary to use third-party software to view .pspimages in Explorer.
mounsey
ram: 24GB
Post by mounsey »
Forriner wrote:I've never had problems with Windows and PSP, so it's just trying things out.
Thanks for the advice. I'll give this a try too soon. John.
TimW
Post by TimW »
Just a quick FYI - PSP Handler Setup from Bot Productions integrates itself into Windows File Explorer. No need to run third-party software to view "pspimage" files.
mounsey
ram: 24GB
Post by mounsey »
Hi. I've tried this - and also the freeware tool linked to from a prior reply.. but sadly I still get no thumbnails for ".pspimage" or older ".psp" image files.
Running out of options here.. really frustrating! Thanks again for the offer of help and tips though, means a lot.
John_
