Aftershot Pro 2 doesn't recognize kit prime lens from my GX7: Lumix G 20mm f/1.7 lens
This lens is in a database and I can choose it manually which is a huge pain when photos taken with different lenses are in the same folder.
The other lens is properly detected: Lumix G Vario 45-200mm f/4.0-5.6
Is there a way to fix it?
Application vers.: 2.4.0.119
Product Name: AfterShot 2 Registered
Built on: Wed Jan 13 2016
Platform: Linux
Language: en
Cheers,
Daniel
Aftershot 2 lens not detected Lumix G 20mm f/1.7 lens
dannysatan
- Corel programs: AfterShot 2 Pro
dannysatan
Re: Aftershot 2 lens not detected
Ok, I've installed AF3 trial and it recognized lens as Lumix G 20mm f/1.7 II but uncalibrated. I assume the settings for this lens are the same as for the first version of the lens.
After adding the following to lens profiles Aftershot 2 can now recognized my lens.
Added to profile_panasonictable.txt:
Added to profile_micro43.txt:
Code: Select all
LUMIX G 20/F1.7 II|Lumix G 20mm f/1.7 IICode: Select all
begin lens
group: micro43
multiplier: 2.0
aperture: 1.7
menu_lens: Lumix G 20mm f/1.7 II
cal_abc: 20.0 -0.000100 -0.007400 -0.025000
end
