DVD/CD label inf
Rollason
- motherboard: Intel GM 45
- processor: Intel core i3 2 duo P8400 2.2GHz 1066 MHz 3MB
- ram: 3GB
- Video Card: 1GB ATI Mobility Radeon HD 5650 Graphics Card
- sound_card: JBL 2.1 + SRS Premium Sound
- Hard_Drive_Capacity: 320GB
DVD/CD label inf
I am attempting to print some labels. Brian Cee has assisted me and having used his instructions I have printed successfully. Unfortunately I don't see how I can centralise the print as the dialogue box shows the circles for the prints on the left of centre. I have A4 double disc label sheets which are centralised down the middle of the page and centralised on the two halves. Further, is there any way in which the picture can be increased in size so that it fills the circle of the label. At present this is cut off top and bottom. Many thanks, Rolly.
Re: DVD/CD labeiiinf
There are options to select a paper size, the drop down panel shows a lot of options, maybe one is the same as your labels?
One called Disc and CD Label A4 shows the discs in the middle of the A4.
These also print in centre
Avery 8931 White……
A-One- 29121 etc……
Two discs show but by clicking to select we can print either label.
What make and type of disc labels have you purchased?
Resizing the image
After adding your own image you should be able to resize by dragging the yellow handles.
If you first create a square image then it seems easier to fit to disc and retain the aspect ratio
Avery 8931 White……
A-One- 29121 etc……
Resizing the image
Re: DVD/CD label inf
You just need to make some adjustments as follows
and
and
