Analogue to digital convertors
Rollason
- motherboard: Intel GM 45
- processor: Intel core i3 2 duo P8400 2.2GHz 1066 MHz 3MB
- ram: 3GB
- Video Card: 1GB ATI Mobility Radeon HD 5650 Graphics Card
- sound_card: JBL 2.1 + SRS Premium Sound
- Hard_Drive_Capacity: 320GB
I have a Canopus convertor which my computer fails to recognise. Can you advise on possible solutions or recommend a convertor? The ones I have found on the internet seem very cheap. Roy
John-T-Smith
- motherboard: ASUS Sabertooth
- processor: Intel i7
- ram: 32 Gig
- Video Card: nVidia GTX760 2Gig
- sound_card: Motherboard
- Hard_Drive_Capacity: 1152 4SSD
- Monitor/Display Make & Model: Samsung P2770
- Corel programs: VSX9 (19.5.0.35)
Re: Analogue to digital convertors
Which model and how do you connect to your computer?
I use a Grass Valley ADVC 110 which I connect to my computer via Firewire IEEE1394 cable
Canon SX510 HS - MOV H.264 24bit color 1280x720 29.97 fps LPCM 48khz audio
All SSD - 256Gig Boot + 256Gig Temp + 512Gig Input + 128Gig for all Output
Grass Valley ADVC 110 via Firewire IEEE1394 cable to convert analog to digital
I used a USB capture device called Ezcap, that seemed to work ok for me.
View this post referring to that capture device.
http://forum.corel.com/EN/viewtopic.php ... 30#p211330
I also have a Mini DV camcorder that has what is know as Passthrough capability aka Throughput.
Effectively using the camcorder as an Analogue to Digital converter, out of the two the better option. Connect composite cables to camera A/V input, output via “DV out” using firewire to pc.
Most (all?) Canopus converters of which I am aware use Firewire. So can you confirm your computer has a Firewire port? If so, then the failure of VS to "see" the Canopus could be because of the "new" or updated Firewire driver inserted by Microsoft. You would need to reactivate the old or "legacy" driver. Here are the instructions for doing so: http://myvideoproblems.com/ProblemPages ... tureW7.htmRollason wrote:I have a Canopus convertor which my computer fails to recognise.
