change colour of hair
vasilis
sound_card: nvidia GTX 2060
Hard_Drive_Capacity: 500 gb
Monitor/Display Make & Model: ASUS G731GV
Corel programs: VS 2020
Post by vasilis »
hello doew anyone knows how can i change the colour of hair ?i want to make looks realistic.not like a painter.i have PSX7 ultimate
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: change colour of hair
Post by LeviFiction »
That depends on the image. I would like to start off with, there is no perfect way to color hair. And some of the best ways are quite complicated using masks.
An image where the hair is very frizzy, or there is little color difference between the hair and the background, or where there is low contrast between the hair and background are not the best for doing this. And drastic changes in hair color will look obviously fake. Moving from dark to light hair is very difficult to make work, But light hair to dark is much easier.
The easiest method, duplicate the image onto its own layer, then you can use tools like Change To Target Brush, or the color changer tool, play with Hue/Saturation/Lightness or Hue Map. Then you just need to mask or erase the top layer leaving only the hair visible. I then recommend a blend mode of some sort maybe a decrease in opacity so it's not so in your face. The areas you'll struggle with are when hair is in front of the face and there is a visible receding hair-line. Because that'll mix in hair and skin.
vasilis
Post by vasilis »
ok i will try.the change to target tool where i can find?also where i can find a tutorial for masks?how can i work with that?
