Video clip contains no video data
Bimbing
motherboard: Pegatron Odessa chipset H 110
processor: Intel i7-6700 3.4 GHz 4 core
ram: 16 GB
Video Card: NVDIA GeForce GTX 745
sound_card: NVIDIA High Definition Audio Audio Codec ALC3863
Hard_Drive_Capacity: 5450 GB
Monitor/Display Make & Model: HP 2009m
Corel programs: Ulead Videostudio X4
Post by Bimbing »
I try to captur my video footage from a Canon Elura 85 DV camcorder and used the DV format to save and Split-by-Scene. The resulting video clips were stored in the designated folder. When I clicked each clip, the video plays in MS Media Player correctly. However, when I tried to "Insert Video file to Timeline (or Library), an error message appeared "The file uvsxxxxx.avi contains no video data" and thus could not be inserted in the Video Library. There must be a configuration or setting incorrectly set but I could not find it. Could someone help me how to correct this problem. Thanks.
When the same footage was captured in the MPEG format, each clip automatically was inserted in both the Timeline and Library.
bryave
update your VS
Post by bryave »
Is this the first time you insert such file or have done it previously and worked fine? If this is the first time to insert such avi file, maybe you need to update your VS version with its latest patch update from their website. If it worked previously that way, why don't you try inserting other clips instead or recapture it again. ^_^
_______
†bryave
