Circular images Paintshop Pro X9
All Media Lab
Post by All Media Lab »
Created some square flags and want to make them round.
How do I create a circular image?
Thanks & Regards,
David
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Re: Circular images Paintshop Pro X9
Post by Joelle »
Make a circular selection>Promote the Selection to Layer : Shift+Ctrl+P on the keyboard.
This will give you a circular image with a transparent background.
If you want to keep it transparent, save it as a .PSPImage, or a .PNG.
Joëlle
Joëlle
(PSPX9 )
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
You can also play around with Effects -> Distortion Effects -> Polar Coordinates or Effects -> Geometric Effects -> Circle to see if that gives you what you want.
All Media Lab
Joelle wrote:Make a circular selection>Promote the Selection to Layer : Shift+Ctrl+P on the keyboard.
Joëlle
Hi Joëlle,
Yes I found this same method online, but unfortunately it doesn't work here.
I attached the image that appears after export to PNG with Alfa Transparency.
Thanks,
David
Joelle
ram: 16 GB RAM
Post by Joelle »
That's strange..hmm
Have just tried the same thing, blurred the image to see if I get the same.., saved as a .PNG, with Alpha transparency ticked and it's as it should be.
Geen Nederlandse vlag? :-)
Joëlle
Joëlle
(PSPX9 )
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
It looks like there is a texture. Check to make sure there is no texture set for the foreground and the background before doing it. I have seen some oddities with the textures even when you are not using them.
Cassel
https://scrapbookcampus.com
