Load from Stream Error
Bimbing
motherboard: Pegatron Odessa chipset H 110
processor: Intel i7-6700 3.4 GHz 4 core
ram: 16 GB
Video Card: NVDIA GeForce GTX 745
sound_card: NVIDIA High Definition Audio Audio Codec ALC3863
Hard_Drive_Capacity: 5450 GB
Monitor/Display Make & Model: HP 2009m
Corel programs: Ulead Videostudio X4
Post by Bimbing »
Since last week I received an error "Load from Stream Error" when I opened VideoStudio 9.0. In the Video Library there are two blank video clips (solid white in color) with 2 diaginal lines from two opposit corners. It is very annoying because I had to click OK twice for each error message bfore I could continue. What caused the problem? How could I delete those blank video clips and get rid of the error message?
Any advise would be much appreciated. Thanks
THoff
Post by THoff »
Once the clip is selected, you can press the Delete key to delete the clip. A clip can become inaccessible if the codec is removed from the system -- without more information about what you did (and what changes might have been made recently), it's impossible to tell. Some codecs also expire after a trial period, including DivX Pro, which is quite popular.
