Unable to open file, please verify file is valid
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
When I double click jpeg images that I have taken my self that usually open in PSpro X5, I get a message" Unable to open file, please verify file is valid".So I tried to open them via file open and when I navigate to the pics I notice that the ones that will not open have a pad lock next to them.Can any one tell what is going on here, why it has happened and how do I sort the problem.
Ken
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: Unable to open file, please verify file is valid
Post by MarkZ »
Have you tried checking the properties of the files under Windows Explorer to see how they differ from the files you can open?
Mark
Ken Veal
ram: 32 GB
Post by Ken Veal »
1 Most of the pics I took are now not showing the date taken which has been the case up until now
2 All of the files concerned are jpegs
3 All imported jpegs open in PSPro and have the date showing when I hover over the image on the hard drive.
4 I think this is something to do with the padlocks that show as if they are protected or the like.
5The thing is that all the images that now will not open have previously done so so, something has somehow changed to cause this issue
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Have you checked the security settings of each file or the ownership?
Ken Veal
ram: 32 GB
Post by Ken Veal »
How do you do that ?
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Post by Forriner »
It looks like It might have something to do with Sharing in Windows 7.
I found an article about file and folder locks that looks interesting.
And another possibility from Microsoft: https://answers.microsoft.com/en-us/win ... d2dbe10287
Ken Veal
ram: 32 GB
Post by Ken Veal »
There are two ways of removing the lock icon.
Method 1:
a. Right click on the folder and click on “Properties”.
b. Go to the tab “Sharing”.
c. Click on “Share”.
d. Select the usergroup from the dropdown e.g. Everyone if you want to share it with everyone and then click on Share to remove the lock from the folder.
The usergroup “Everyone” will have access to the folder then. The folder no longer has special permissions and Windows 7 will therefore remove the lock icon.
Method 2:
a. Right click on the folder and click on“Properties”.
b. Go to the tab “Security”.
c. Click on the “Advanced” button at the bottom.
d. Click on “Change Permission”.
e. Select your user account and check the option “Include inheritable permissions from this object’s parent”.
f. Click on apply to remove the lock icon.
The lock icon will be removed because the folder now inherits the permission of the parent folder. If that folder does not have any special permissions you will successfully remove the lock from the folder.
I followed method 1 , in item e of method 2 “Include inheritable permissions from this object’s parent” was already selected.So I am still unable to open the images mentioned
Ken Veal
ram: 32 GB
Post by Ken Veal »
If any one is interested I have found a solution to my problem.Fortunately, I had the offending images on a CD.I copied and pasted/replaced the images in the hard drive , as soon as this was done I was encouraged by the fact that on hovering over them they showed the date of being taken and showed the image.They all opened up in PSPro.But I still have no idea why this happened in the !st place because I had made no changes anywhere.They were the same files from the same source
