Someone might find this quite interesting.
Using CAM monitor and a 3.3sec 4K - .MOV - H.264 - MPEG 4 Low AAC.
5 instances of the file is placed on the timeline for load testing. Render is saved as MPEG-4 AVC (1920x1080, 25p, 15bps)
It's basically this test without OBS running - https://youtu.be/nH8-cAOtptg
RAM usage went up 0.4GB on the i7 4770 so I didn't bother checking the others.
All tests off-line. On-line off-line seems to make no difference.
Video is 5 pieces of 4K - see above - 16.15sec total.
i7 4770 - GT210 - Win7 64 - X9.5
At rest : CPU 7% - GPU 0%
Edit/Move cursor on timeline : CPU 19% - GPU 0%
Rendering : CPU 30% - GPU 1%
Time : 1:22
Conclusion - Render speed pretty fast.
i7 960 - GT610 with std Win driver - Win7 64 - X9.5
At rest : CPU 0% - GPU na%
Edit/Move cursor on timeline : CPU 19% - GPU na%
Rendering : CPU 31% - GPU na%
Time : 1:54
Conclusion - GPU doesn't do much so I didn't bother installing the GT610 drivers. Average speed
i7 960 - GT610 with std Win driver - Win7 64 - X7
At rest : CPU 4% - GPU na%
Edit/Move cursor on timeline : CPU 4% - GPU na%
Rendering : CPU 44% - GPU na%
Time : 1:01
Conclusion - GPU doesn't do much so I didn't bother installing the GT610 drivers. Speed ok.
Core2Duo E8500 - GT210 - XP 32 SP3 - X7
Edit/Move cursor on timeline : CPU 9% - GPU na%
Rendering : CPU 88% - GPU na%
Time : 2:02
Conclusion - Can't run CAM because XP is too old so I used Task Manager. Slow-ish
Core2Duo E8500 - GT210 - Win7 64 - X9.5
At rest : CPU 5% - GPU 0%
Edit/Move cursor on timeline : CPU 68% - GPU 0%
Time : 2:53
Rendering : CPU 83% - GPU 3%
Conclusion - Rather slow-ish. This one has a mech HDD where as the others are all SSD, but when it was rendering the usually noisy HDD was quite, indicating it wasn't being used.
i7 4770 - GT210 - Win7 64 - VS11.5
At rest : CPU 5% - GPU 2%
Edit/Move cursor on timeline : CPU 18% - GPU 0%
Rendering : CPU 22% - GPU 3%
Time : 0:51 - VS11.5 can only do 720p MPEG4
Conclusion - Render speed fast.
PC Load Testing - now with render times
Old Grey
- motherboard: MSI Z87-G41 PC MATE
- processor: i7 4770K
- Video Card: MSi GeForce GT1030
- sound_card: Realtek ALC887 onboard
- Hard_Drive_Capacity: 8TB
- Monitor/Display Make & Model: Philips BDM3201FD 32" + Benq G2400WD 24"
- Corel programs: VS-X9
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Old Grey
Re: PC Load Testing
I went back and measured the render times, not for any reason, just because it's interesting.
