VS X9 Preferences-performance tab
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I have set PAL in the general tab of preferences.Under Video Proxy Options in the Performance tab, the frame rate shows 29.97 fps.I guess PAL needs 25 fps.How do I change this setting.I have enabled Smart Proxy and
auto generate proxy template (recommended) is ticked
Re: VS X9 Preferences-performance tab
Ken -- if you go to Settings > Preferences, then on the first General tab, you will see down the bottom we now have have the choice between PAL and NTSC. You need to pick PAL to get all the templates etc to be set to PAL standards.
Ken Veal
ram: 32 GB
Post by Ken Veal »
I have set PAL at the bottom of the general tab and at the top of the edit tab, restarted VS and then the PC but 29.97fps still shows in the performance tab
Hi Kenneth
Normally I leave “Auto generate proxy template” selected (ticked)
The 29.97 fps below is used as the default template when the auto option is deselected.
Once deselected the settings and Template button becomes active, we could then select another template using Pal.
But as I say with “Auto generate………” selected there is no need as the process is automatic.
Ken Veal
ram: 32 GB
Post by Ken Veal »
To clarify,
ifAuto generate proxy template” is selected (ticked) and below shows 29.97 even though I am using PAL there is nothing to change.
Ken (also may be a.k.a. Arnie- said I would be back)
Hi Kenneth
Yes that is how I understand using Smart Proxy, only when using a manual approach to set a template do you have to worry about the settings.
