Hello board,
during my process I copy the pics from original folder to folder.
I get the situation that after the copy (or even an export with i.e. picasa) of the picture the metadata is not displayed correctly in ASP3. It seems to be connected with the change of the tags last changed of the file.
The metadata are still there. This can be ssen in exif-tools, in windows explorer or even in psp x9 (image details).
The problem is that after such a copy and the wrong recognition of metadata a catalogue contains no metadata anymore (or just the copy date). This behaviour is strange.
Did you get the same errors?
How can this be fixed?
Thanks in advance.
Best regards,
Jbecher
EXIF Metadata not visible when JPEG is copied to folder
jbecher
- Corel programs: ASP3, PSP X9
jbecher
Re: EXIF Metadata not visible when JPEG is copied to folder
Hello,
i just found an work around at least for pictures copied/edited/cheanged via picasa.
You must remove the JFIF-Tags from the file (I did it with exiftoolgui) and now the metadata are displayed correct in asp3.
Therefore I aasume asp3 has problems to resove the jfif-tags...
Jens
Jens
