I've spent most of my post-Xmas freetime trying to work out why I can't add MPG video files to my timeline. All other video types appear to work fine but any effort to add an MPG causes issues.
The MPG video can be inserted and appears on the timeline but there is no video (probably no audio either but never checked). If I try to edit the imported MPG, the program crashes with an unexpected error type pop-up.
Seems to be a number of people around other sites with the same issue so I have tried various things like downloading DivX and making it default for MPGs but that made no difference. I even changed the suffix from .MPG to .MP4 and even .MOV but that just threw up file format errors.
Most of these MPGs were created in older versions of VideoStudio but I really don't want to go back to those.
Any ideas ?
Unable to add MPG videos to timeline
Paul33
- motherboard: Hewlett-Packard 0A9Ch XU1 PROCESSOR
- processor: Intel Xeon E5430 2.66GHz x 2 Dual Core
- Video Card: NVIDIA GeForce GTX 1060 6GB
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: BenQ GW2765
- Corel programs: VideoStudio 2020 Ultimate
Re: Unable to add MPG videos to timeline
Are you able to import the videos to the library.
Create a new library page
Right click the library and choose Insert Video, browse for your files.
Now tell us the properties of those video clips.
Right click a clip and choose properties, what are they?
take a snapshot of that window to create a jpeg image to attach to your post (Atl+PrtSc will copy to clipboard.)
Paul33
I can import the MPG(s) but they won't play and there is just a blank container with no obvious video/audio.
Screenprint attached.
Hi Paul
Sorry for delay in our reply
Certainly I don’t see anything wrong with those properties and don’t see any reason why they will not play.
I have some older Mpegs that play ok although with Digital Dolby Audio, LPCM should be ok.
I don’t really know what to suggest other than re-installing the program.
I assume you are using the latest patched version, go to Help – Check for updates.
Latest version is 19.5.0.35, view Help – About.
1 / You can try renaming the file to use MPEG or MTS as the files extension rather than MPG, but really clutching at straws here.
2 / Go to Settings Project Properties and set to DVD (720 x 576, 16:9, 50i, 8Mbps) which should match the clips properties, Edit the template to use LPCM Audio from the Compression tab., does that help?
If you have a smaller video clip, can you upload to a sharing site, OneDrive, GoogleDrive, DropBox.
We can try your video on our pc’s.
John-T-Smith
- motherboard: ASUS Sabertooth
- processor: Intel i7
- ram: 32 Gig
- Video Card: nVidia GTX760 2Gig
- sound_card: Motherboard
- Hard_Drive_Capacity: 1152 4SSD
- Monitor/Display Make & Model: Samsung P2770
- Corel programs: VSX9 (19.5.0.35)
You might use https://handbrake.fr/ open source transcoder/converter to see if the files will convert to something that will edit
Canon SX510 HS - MOV H.264 24bit color 1280x720 29.97 fps LPCM 48khz audio
All SSD - 256Gig Boot + 256Gig Temp + 512Gig Input + 128Gig for all Output
Grass Valley ADVC 110 via Firewire IEEE1394 cable to convert analog to digital
