Capturing "live" video...
dannyrod
Is UVS 7 SE Basic capable of capturing live video (meaning I am bypassing the miniDV tape)? I connected my camcorder to the pc without a tape in it and then set the program to capture but the video's framerate was slow junk and the video was choppy.
P.S. The program works fine when capturing from a miniDV tape playing back on the camcorder.
THoff
UVS has no idea whether there is a tape in the camcorder or not -- it just sees the DV data stream coming from the camcorder. Capture performance will be identical with and without a tape.
The problem has to be something else, like a background process, low memory, or a difference is your capture settings (such as attempting to capture to MPEG format).
dannyrod
I used a 25ft firewire cable. Is that the problem? It may be my laptop has low specs (1.6Ghz / 512mb DDR ram / 64mb Radeon Mobility) but I thought that would be ok to capture video. I captured at DV format and it worked fine the last time. The only difference was that this time I was capturing to an external 80GB usb drive instead of the hard drive.
dannyrod
THoff
Q: What is the maximum length a FireWire (A) cable can be?dannyrod wrote:I used a 25ft firewire cable. Is that the problem?
A: The maximum cable length for connecting device to device with a 400Mbps cable is 4.5-meters (14.85ft). The Firewire specification calls for 10 meter (32ft) cables that may be used in conjunction with a repeater when it is necessary to extend FireWire cables over long distances. FirewireDirect does not offer these cables at this time because tests have shown them to be unreliable in some situations. We suggest using 4.5 meter cables and hubs when needing to extend to greater distances and don't recommend 10 meter cables (if you can find them) to our customers.
